Need Help! Installation of Radiator Panel
How do you remove the six plastic nuts in front of the radiator to install a radiator panel?
Don't want to do any damage.
They do not seem to pull out.
Thanks in advance.
Thanks in advance.
Not the inside plastic piece that is the problem.
Once that is pulled up, I still cannot pull the entire piece out.
Very tight fit.
By the way - carbon fibre looks great from Auto Tecknic.
Very tight fit.
Jason is right. Just pop up with the screwdriver and then push it down about halfway. Pull the clip up from the base (you may want to keep a finger on top of plastic that popped up so that it doesn't go back up and lock itself). Should come off easily now.
CFAUVEL
Oct 1, 2015 03:20 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
