My LED lighting
Old Jun 2, 2005 | 09:02 AM
trescincuenta's Avatar
trescincuenta
Originally Posted by Conceyted
also, i have heard that changing out the rear brake lights with leds will make it harder to see if you are on the brakes or not. (hard to tell the difference between bright and VERY bright) is this true?
Yes its true, Im contemplating putting a resistor in the wire that powers the lowervoltage taillight so that its dimmer. The difference between tail and brake is not as much as I would have liked. Although if you'e following me and don't see the top mount factory LED's light up when I brake you're blind
Old Jun 2, 2005 | 09:05 AM
trescincuenta
Another question. did you get hyperflash with led bulb turn signals or did you strap on the load resistors to each turn signal side
I should have taken a video with the turn singal on as well, because when you use the hazards you don't get the hyperblink, but with only the turn signal on you do. I did not put the load resistors because I actually like the fast blink. It accentuates the instant on/off of LED lighting. Hyperblink on a standard filament bulb sucks since it fades on and off when you blink too fast it all kinda blends together, not with the LED's
Old Jun 2, 2005 | 09:09 AM
Conceyted's Avatar
Conceyted
can we maybe get a video of how fast it actually is? maybe I will like it too :-D
Old Jun 2, 2005 | 09:32 AM
trescincuenta
Sure, ill make a quick vid later today when I get home, weather permitting.
Old Jun 2, 2005 | 11:19 AM
Conceyted's Avatar
Conceyted
awesome thanks for the help.
Old Jun 3, 2005 | 07:23 AM
OUTBURZT's Avatar
OUTBURZT
THOSE reverse LEDS are sweeeet
Old Jun 3, 2005 | 07:49 AM
HockeyZ39's Avatar
HockeyZ39
Go check your list, maybe you are sponsored by them!
Old Jun 3, 2005 | 07:53 AM
OUTBURZT's Avatar
OUTBURZT
grow up man, grow up
Old Jun 3, 2005 | 01:02 PM
Superhung's Avatar
Superhung
That looks awesome!
How hard was it to replace the rear turn signal's? Also, what was the hardest part of the install?
Old Jun 3, 2005 | 01:55 PM
Superhung's Avatar
Superhung
Just placed an order for everything that was listed (except the license plate LED's) + four load resistors. Install will be next week since I'll be heading down to my tuning shop for some other work and will have them install the LED's as well. Can't wait =)
Old Jun 3, 2005 | 02:55 PM
itsjoshufocker's Avatar
itsjoshufocker
man just curious.. how do you take out the headlights and rear signal/reverse lights to put new bulbs in there? ive been tryign to figure it out but no luck
Old Jun 3, 2005 | 10:51 PM
lgbdog1's Avatar
lgbdog1
At http://www.superbrightleds.com/1157.htm it says "Do not use LED bulbs in the same housing with head lamps, the heat will cause them to fail quickly". Are there problems associated with using these in the headlight housing?
Aside from that, +1 Hoping to see a video of the hyper flash
Old Jun 3, 2005 | 10:54 PM
GQ 350z's Avatar
GQ 350z
How long does it take them to ship? Besides my confirmation email I havent gotten anything or any word from them.
ravi
Old Jun 4, 2005 | 02:29 PM
Superhung's Avatar
Superhung
ravi
I just placed my order yesterday with the '2-day' shipping option. I will post when the stuff arrives.
Old Jun 5, 2005 | 09:12 PM
OUTBURZT's Avatar
OUTBURZT
Mine havent came in yet
Old Jun 6, 2005 | 09:11 AM
valdeztke's Avatar
valdeztke
look below
Old Jun 6, 2005 | 09:12 AM
valdeztke's Avatar
valdeztke
subscribing .. due to my retarded internet at work ( stupid DOD ) wont let you do anything!!
lol
How hard is it to run wires from the turn signal wiring to another location .. I sort of blacked out my headlights nad need to relocate my turnsignals ..
Old Jun 6, 2005 | 10:04 AM
  #38
Jun's Avatar
Jun
I used to like the fast blink, but it will get annoying after awhile, especially when you are sitting on the turning lane and it's taking you a long time to turn. I have the load resistors and i'm glad i got them
Old Jun 6, 2005 | 12:34 PM
  #39
Superhung's Avatar
Superhung
Hey Jun, you only need four load resistors correct?
Old Jun 6, 2005 | 05:38 PM
  #40
GQ 350z's Avatar
GQ 350z
Recieved my LEDs today. No doubt they are very very bright.
its more of a focused light though.
ravi
