My LED lighting
Old Jun 29, 2005 | 01:48 PM
  #101
Apexi350z's Avatar
Apexi350z
Charter Member #50
Originally Posted by COJ_General
Has Anyone Had Some Of The Led Lights Blow Out?!? I Replaced All The Lights In The Car With These Leds And Some Of The Leds Lights Are Blown....
I had mine went out before.. the small 4 led wedge bulb... so it's pretty common I think.
Old Jun 30, 2005 | 09:47 AM
  #102
Paul350Z's Avatar
Paul350Z
Living in 350Z
Originally Posted by itsjoshufocker
guys, since i have the front 2 lights LED and the rear lights the regular bulbs, will the 3ohm capacitor still work okay? i just relized this because im sure everybody else has LED front and rear signal lights... where as mine is LED in front and stock in the rear... will i blow something?
You need a 6 ohm resistor for one bulb in the circuit - one resistor per side. If you replace both bulbs the 3 ohm resistor is used.
The six ohm resistor will draw 2 watts, the rear light bulb will draw 5 or 6 and the LED bulb in front will draw about 1 watt for a total of 8-9 watts and the sensors are happy.
The 3 ohm resistor will draw 4 watts, and the two LED bulbs will draw 2 watts for a total of 6 watts and the sensors are happy.
Old Jun 30, 2005 | 11:09 AM
  #103
boma's Avatar
boma
I installed the reverse 15 led bulbs, and they're maybe half as bright as the stock incandescent bulbs.
They look like dim hyper-white bulbs. O well.
Old Jun 30, 2005 | 11:10 AM
  #104
boma's Avatar
boma
Oh and I must say that superbrightleds.com gave me great service. I had a problem with my order and they fixed it right away.
Old Jun 30, 2005 | 11:37 AM
  #105
350z_2NR's Avatar
350z_2NR
can you tell me what size and what you exactly ordered for everything except the plate light and kinda tell me how you did it
Old Jun 30, 2005 | 11:41 AM
  #106
isugoo's Avatar
isugoo
There is exact numbers/quantity/location list in early pages.
Do your homework.
Old Jul 10, 2005 | 10:49 PM
  #107
itsjoshufocker's Avatar
itsjoshufocker
whats the website with all the bulb sizes
Old Jul 11, 2005 | 09:56 AM
  #108
isugoo's Avatar
isugoo
read through all the post.
you will find all the sizes and the website.
Old Jul 27, 2005 | 07:49 PM
  #109
Roger V's Avatar
Roger V
What are the led sizes of the top strip that lights up when you brake? [top of hatch] I want to change all my break lights to leds because I love the look.
Old Jul 27, 2005 | 08:02 PM
  #110
dkny_boi's Avatar
dkny_boi
You'll love this then... because that strip is leds
Old Jul 27, 2005 | 08:04 PM
  #111
boma's Avatar
boma
I don't know if those are replacable. It would be highly illegal to change those to a different color.....
Old Jul 27, 2005 | 08:54 PM
  #112
Jergens's Avatar
Jergens
I think the LEDs on the parking and reverse lights are fantastic. Might have to order some..
~Josh
Old Jul 28, 2005 | 03:58 PM
  #113
Roger V's Avatar
Roger V
Oh, really? It leds from the factory?
boma: I don't want to change them to a different color, I just like the instant on and off of leds.
Old Aug 5, 2005 | 07:49 PM
  #114
TiPIACE's Avatar
TiPIACE
all this talk of the brake lights not being bright enough,
has anyone tried using white LEDs in the brake light? They would definitely be brighter (white light is visually brighter than red), and the red lense will make them appear red on the outside anyway
im going to order white leds, and see how they go
Old Aug 5, 2005 | 09:34 PM
  #115
dkny_boi's Avatar
dkny_boi
Let us know how they go. I didn't since the site recommends red LEDs for brake lights. Maybe the colour might be off since white leds sometimes seem blueish.
And yes Roger V, the third brake light strip is LEDs... clear that light up red.
Old Aug 5, 2005 | 09:38 PM
  #116
esfand's Avatar
esfand
i have the same thing but mine arent as bright??????????????
Old Aug 7, 2005 | 02:14 PM
  #117
pyindeem's Avatar
pyindeem
subscribed
Old Sep 30, 2005 | 05:20 PM
  #118
sponsorsthisway's Avatar
sponsorsthisway
Does anyone know if the 30 LED clusters would fit? Also, would i need these load resistors as well?
Old Sep 30, 2005 | 05:48 PM
  #119
UofA350Z's Avatar
UofA350Z
Hey everyone, I'm still pretty new to the forum but I had an LED question. I read at one point that someone had a parking light LED melt since it's in the headlight housing but haven't come across any other problems. Has anyone else with parking light LEDs experienced any sort of problem like that? Thanks in advance.
Old Sep 30, 2005 | 06:15 PM
  #120
DIGItonium's Avatar
DIGItonium
I make my own LED automotive bulbs. For the parking lights, it will only melt when there's a bad short with the circuit inside the plastic wedge. The cheapo bulbs tend to "fall apart" easily so bits of solder or wire might get caught between the + and - terminals and cause a melt down inside.
