My LED lighting
Old Jun 6, 2005 | 05:40 PM
  #41
Paul350Z's Avatar
Paul350Z
Living in 350Z
Originally Posted by itsjoshufocker
man just curious.. how do you take out the headlights and rear signal/reverse lights to put new bulbs in there? ive been tryign to figure it out but no luck
Me too.
I've started digging through the trunk without luck, looked under the bumper and there's the exaust there ... I'm starting to see if the bumber peels off the tail now. Nothing in the search engine was of help.
Ya' think we could gather such information into a sticky?
Old Jun 6, 2005 | 05:46 PM
  #42
GQ 350z's Avatar
GQ 350z
For the rears, you need to take out the taillights. when you reach your hand in there feel for the two 'light sockets' and just twist. The bulbs will be easily acessible.
As for the front parking lights, jack the car up, and take out the inner fender liner and you will see the bulbs. Do a search, there are numerous posts about this.
ravi
Old Jun 6, 2005 | 06:24 PM
  #43
Paul350Z's Avatar
Paul350Z
Living in 350Z
OK back and done - DO NOT REMOVE THE REAR BUMPER COVER.
New post to follow with pictures.
Old Jun 6, 2005 | 06:47 PM
  #44
tabrizio's Avatar
tabrizio
Everything looks great. I want to do something just like this...I dont know too much about lights and what not, how hard of an install is this?
Old Jun 7, 2005 | 05:49 AM
  #45
Jun's Avatar
Jun
Originally Posted by Superhung
Hey Jun, you only need four load resistors correct?
You only need two, one for each side, if you get the 3ohm resistors. Easiest way is to connect them to the front turn signals, since the rear ones are harder to reach.
You can get four of them, one for each corner, if you get the 6ohm resistors. But why do that when you can save yourself the time and money?
Old Jun 7, 2005 | 11:24 AM
  #46
bigpete355's Avatar
bigpete355
Did people need to put a resistor onto the stop / tail light bulbs as one was brighter than the other or am i getting the wrong end of the stick?
If you did does the resistor in on the tail lights did you put it inline with the wiring for it or scotchlocked onto the wire up whe side? Just wondering as my led lamps should be here tomorrow and im looking to do this
Old Jun 7, 2005 | 12:17 PM
  #47
Jun's Avatar
Jun
No need to put it on the taillight, since there is no blinking going on. You only need to put it on the turnsignals. And if you are debating between putting them on the front signals or the rear signals, my suggestions is go with the front, much easier access, and don't complicate yourself more than you have to.
Old Jun 7, 2005 | 12:46 PM
  #48
Netko350Z's Avatar
Netko350Z
Excellent!!!!
Old Jun 7, 2005 | 01:47 PM
  #49
bigpete355's Avatar
bigpete355
Ahh cool mate no ive got chrome bulbs for turn signals but replacing all the others for LED :-D
Old Jun 7, 2005 | 03:20 PM
  #50
r.c.y.k.'s Avatar
r.c.y.k.
what part number for the map light then?? i know it is DE3175, but in their site, they only have diff size with their own part number.
Old Jun 9, 2005 | 06:10 AM
  #51
isugoo's Avatar
isugoo
+1.
i'm holding ordering leds because i want to order 2 maplights together.
anyone?
Old Jun 9, 2005 | 10:22 AM
  #52
isugoo's Avatar
isugoo
Originally Posted by isugoo
+1.
anyone?
Ok. I did some research.
It's 31mm. So order the one with 31mm (it's in the 2nd page) from the those domelights.
Old Jun 9, 2005 | 11:18 AM
  #53
boma's Avatar
boma
Anyone have pics of how the led dome lights look? I don't want them if they're not brighter.
Old Jun 9, 2005 | 11:23 AM
  #54
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Subscribing...
Old Jun 9, 2005 | 11:27 AM
  #55
boma's Avatar
boma
Good Job! I knew about these led websites, but I was hesitant to buy them until now.
Old Jun 9, 2005 | 11:49 AM
  #56
isugoo's Avatar
isugoo
i just made order. (with dome lights)
i will take some pics after i install it. (used ground shipping so it will take a while)
Old Jun 9, 2005 | 12:38 PM
  #57
Wicked_Limitz's Avatar
Wicked_Limitz
are those part numbers the same for a G?
Old Jun 9, 2005 | 12:58 PM
  #58
jbenedict's Avatar
jbenedict
Originally Posted by trescincuenta
Yes its true, Im contemplating putting a resistor in the wire that powers the lowervoltage taillight so that its dimmer. The difference between tail and brake is not as much as I would have liked. Although if you'e following me and don't see the top mount factory LED's light up when I brake you're blind
Has anyone tried this resistor yet? I am trying to figure out a way to "dim" the parking lights in the brake so that they aren't as bright, to make a bigger difference between parking and brake lights. I don't like the idea of parking lights being almost as bright as the brakes. I am no 12V guru by any means so I have no idea what ohm to start at for this.
Old Jun 9, 2005 | 01:32 PM
  #59
Superhung's Avatar
Superhung
I just received my order for everything that's listed (minus license plate LED's). Install will take place tomorrow. Will post pics when I get everything on =)
Old Jun 9, 2005 | 06:22 PM
  #60
Paul350Z's Avatar
Paul350Z
Living in 350Z
I'm using 4 LED white lights - 3022-W4
