Aerosync N-Style POLYURETHANE front bumper
Old Aug 29, 2005 | 11:14 PM
  #121
JP_WRX's Avatar
JP_WRX
Hehe...our local AZ350Z.com group had a photoshoot set up at with these 2. I'm a big fan of the blonde but could've done without the dark haired one. Picky you ask? Yes, yes I am Maybe once I get ahold of the high res pics I can post those and zoom in on the 'goods'.
Old Aug 30, 2005 | 02:21 PM
  #122
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
keptrying - how did you avoid there not being exposed screws?
Old Aug 30, 2005 | 03:43 PM
  #123
keeptrying's Avatar
keeptrying
There are several mounting locations (basically a build up of plastic) on the back of the bumper. I made sure to buy short screws and tap shallow holes. There is definitely a potential/risk to drill through the bumper if you're not careful.
Old Aug 30, 2005 | 09:08 PM
  #124
MyNismoRoadster's Avatar
MyNismoRoadster
Originally Posted by .Sin.
gruppe-s seem more reliable then e-bay...
Except for the fact that the seller on ebay is the maker of the bumper you are about to buy anyways.
Old Aug 31, 2005 | 05:37 PM
  #125
Z1 Performance
Former Sponsor
keeptrying - thanks - I see what you mean now (bumpers arrived yesterday) - looks like we will try a combo of the screws and permatex
Old Aug 31, 2005 | 07:49 PM
  #126
KenWH's Avatar
KenWH
For custom mesh mounts:
Guys, my body guy showed me a neat and easy way for installing mesh in bumpers etc. To mount the mesh into bodykit's he uses stuff he called "cat hair" filler and hardner. He uses a putty knife to lay dabs around the back of the bumper opening which he then embeds 6"-8" long pieces of thin but strong wire into. You want to place the dabs far enough away from the openings edge so they won't be seen. He fits and trims the mesh so it's oversized for the opening enough to cover the cat hair/wire "mounts".
Once the filler(with wire in it) sets up and is bonded to the back the bumper, he just runs the wire through the mesh and twists it tight which pulls the mesh into the back of the bumper for a tight fit. To clarify...the mesh is mounted from the back of the bumper and the "mounts" are completely hidden when done right.
The day he showed me this I was helping him with an older eclipse that was getting a body kit installed. The front bumper had several large odd shaped openings that were getting mesh...his method worked great.
Old Sep 5, 2005 | 08:33 PM
  #127
anotheraznguy's Avatar
anotheraznguy
the front bumper looks awesome i saw it at their showroom... good quality urethane.. top notch... can't wait to save enogh money to grab this up... Gruppe -s is an awesome place..
Old Sep 8, 2005 | 01:34 PM
  #128
Gruppe-S's Avatar
Gruppe-S
Vendor - Former Vendor
Just an update:
I have asked to the manufacture to look into the sidemarker fitment so the next shipment will be fix and good to go.
Thanks,
Tom
Old Sep 8, 2005 | 01:40 PM
  #129
sbcbaseball's Avatar
sbcbaseball
Do you have ETA on next shipment?
Old Sep 8, 2005 | 01:44 PM
  #130
Z1 Performance
Former Sponsor
FYI guys (my OEM front bumper was off so I had a chance to look) - even with the OEM sidemarkers (I had the "dark" Japan spec ones), there is a gap at the top and bottom of the bumper itself
Old Sep 12, 2005 | 05:24 PM
  #131
Z1 Performance
Former Sponsor
what did everyone use to secure their underpanel?
Old Sep 12, 2005 | 06:12 PM
  #132
JPsZ's Avatar
JPsZ
I just punched little holes with a hammer and nail, and used screws with washers to hold the underpanel. I used a hammer and nail cause i didn't have a drill bit that small, and i wanted the screws to fit tight. Of course, i made the holes on the bumper exactly to where the holes on the underpanel were.
Old Sep 13, 2005 | 03:14 AM
  #133
Z1 Performance
Former Sponsor
interesting - one the bumper I fitted Friday (my car), the underpanel did not sufficiently overlap the bumper to allow for this - the bumper edge came right up to the underpanel edge so there was no way to attach the 2 together via screws. I suggested they need to mold the OEM type tabs in and prepunch the holes
Old Sep 15, 2005 | 01:01 AM
  #134
Dragonstyle's Avatar
Dragonstyle
Gruppe-S: you guys also carry the replica Nismo front bumpers for the g35 coupe?...in poly?...with a cut out made for towhook access?
Old Sep 15, 2005 | 04:21 PM
  #135
Gruppe-S's Avatar
Gruppe-S
Sorry, no G35 yet. We only have it for 350z right now.
Tom
Old Sep 17, 2005 | 08:24 PM
  #136
boosthappy's Avatar
boosthappy
Default My Pics
Well it took me a while to install my bumper but here you go, the lights did fit but there is like a 1/8 - 1/4 inch gap on each side, other than that I love it changes the look of my Z totally!
Attached Thumbnails Aerosync N-Style POLYURETHANE front bumper-350zr1.jpg   Aerosync N-Style POLYURETHANE front bumper-350zr2.jpg   Aerosync N-Style POLYURETHANE front bumper-350zr3.jpg   Aerosync N-Style POLYURETHANE front bumper-350zr4.jpg
Old Sep 18, 2005 | 05:30 AM
  #137
Z1 Performance
Former Sponsor
I managed to get the same amount of gap as the stock bumper has with some careful adjustments...I'll have pics posted in the next few days as we are doing a shoot today
Old Sep 21, 2005 | 03:38 PM
  #138
Gruppe-S's Avatar
Gruppe-S
Looking good!
Tom
Old Sep 22, 2005 | 08:44 AM
  #139
LiNks's Avatar
LiNks
What are your guys opinions on cutting out the entire center of the bumper including the license plate bracket and the bar that runs across under it? I looked over the bumper and am aware that youd have to smooth out the lines around the mouth of it to make it look even with no gaps but overall how do you think it will look, with a FMIC? Also do you guys agree that if you just cut out that license plate bracket that the bar under it will be very flimsy and probably flap up and down at faster speeds?
Old Sep 23, 2005 | 10:06 AM
  #140
LiNks's Avatar
LiNks
Default Kinda Like This
I did a real quick photoshop of his car with the center cut out and kind of a front mount..... what do you guys think..
