Seat belt on Z...
Old Aug 10, 2005 | 08:57 AM
shortbus1981's Avatar
shortbus1981
Default Seat belt on Z...
Ok, is it me or do others feel the seat belt on the Z gets a tad to far up on your neck? I am 5'11" and it still hits me on the neck. I have that little adjuster set down all the way, but it always manages to click back up a notch and thus place the belt right near my neck again. Not only is it uncomfortable, but it's also dangerous. Anyone else have this issue, or might know of a fix?
Old Aug 10, 2005 | 09:18 AM
andrew350z's Avatar
andrew350z
get taller
Old Aug 10, 2005 | 09:31 AM
raptorbh12's Avatar
raptorbh12
man im 5'7" and it runs right accross my chest. Maybe your seatbelt is just weird?
Old Aug 10, 2005 | 09:33 AM
shortbus1981
Originally Posted by andrew350z
get taller
Wish I could.
shortbus1981
Well it runs across my chest but the top left part, where it attaches to the body of the car, sits kinda high.
Old Aug 10, 2005 | 09:34 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
Seems fine for me. Is the belt on the coupe attached differently than on the roadster? I'm thinking the coupe may have it attached a tad higer since it has a full b pilar.
Old Aug 10, 2005 | 09:42 AM
andrew350z's Avatar
andrew350z
haha not trying to be a dick i just read taht again and i bet i sounded like an a$$. yeah i don't know i am 5' 9''and it is fine for me.
Old Aug 10, 2005 | 09:51 AM
umzzz's Avatar
umzzz
Cwest Army
do you have your seat layed back or slid pretty far back? you could try and sit a little closer to the wheel...makes shifting a while lot easier too if you have manual
i had the same problem until my friend told me to move my seat up so that when i grab the shifter it makes a 90 degree angle and now the problem is gone...seatbelt sits square across my chest now.
Old Aug 10, 2005 | 10:19 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
What adjuster?
Chris
Old Aug 10, 2005 | 10:30 AM
shortbus1981
Originally Posted by HyperSprite
What adjuster?
Chris
That plastic clip thing that the belt attaches to. It adjusts up and down a tad.
Old Aug 10, 2005 | 10:38 AM
HyperSprite
Mad Scientist
The belt holder attached to the seat was added in 2004.5 based on customer complaints. It's only there to make the belt easier to reach and to keep the unused passenger side from clanking around. It does make me wonder if there might be a way to mod it to stiffen it up or lock it in position to help you out. I am about to go to lunch, I will look at mine and see if I can come up with anything.
Chris
Old Aug 10, 2005 | 12:19 PM
gto88's Avatar
gto88
I am 5'10'', and I don't have this problem.
Old Aug 10, 2005 | 12:41 PM
HyperSprite
Mad Scientist
Default Seatbelt Mods?
A couple of things I thought about while in my car.
Did you try bringing the seat bottom up to get your torso up a little higher? If that seating position works for you, it could solve your problem, if not...
I looked at the belt fixture, the small arm for holding the belt is actually attached to the same bolt as the seatbelt loop and seams to be fixed to match the pivot of the belt loop. The belt loop is a little hard to move but as soon as you pull the belt out, it goes back to it's normal position. If you are mechanically inclined, you might be able to pop off the bolt cover on the belt loop and remove the bolt. Then modify the arm to set a bit lower when the loop is in it's default position. That is what I would do anyway.
Chris
Everybody is build differently, one person can have shorter legs and a longer torso than the next person and they can be the same hight. So while you are lucky this is not happening to you, it certainly could be happening to someone else.
Chris
Old Aug 10, 2005 | 01:00 PM
shortbus1981
Hey, thanks for the info. Im gonna see if there is any type of modification like that, that I can figure out. I just hate having the damn belt near/on my neck like that. However I dont want to take the belt off as thats not safe either.
Old Aug 10, 2005 | 01:15 PM
HyperSprite
Mad Scientist
Hope that helps,
I am all about modding the Z (and everything else I own) to make it fit me better, some of my more random mods are center console arm rest pad (made from a 2004.5 knee pad), air pump type lumbar support, more trunk lighting (white LEDs on the underside of the strut bar), rubber mat in the trunk area (to keep my servers from sliding around).
If you lived closer, I would come over and help you, it sounds like an interesting project.
Chris
Old Aug 11, 2005 | 04:41 AM
Kaitain's Avatar
Kaitain
I'm 5'7" and I have the same exact problem. I have the seat pretty far forward so that's not it.
I just end up putting the belt under my collar but I guess I could get one of those seat belt thingies:
http://performancenissanparts.com/ca...00ee1e4c1b8b56
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Vigman
Nov 17, 2015 04:34 AM
Fixxxercask
Nov 9, 2015 11:10 AM
