LED Problem HELP!
Old Nov 8, 2005 | 06:48 AM
lemonjihwan's Avatar
lemonjihwan
Default LED Problem HELP!
hey guys,
i ordered a 7440 LED lights for my rear turn signals.
and today i installed them. but for some reason,
turn signal blinks real fast.
i dont know why but when i turn on the emergency light on,
it blinks fine with normal speed.
is it somekind of fuse problem?
what do i have to do to fix it?
thanks
Old Nov 8, 2005 | 06:57 AM
djnc's Avatar
djnc
i know turn signals blink fast when it thinks one needs to be changed...maybe it doesn't recognize that there's a light there
Old Nov 8, 2005 | 07:33 AM
lemonjihwan
hmmm... so i guess its not the fuse problem... anybody has any experience about this?
Old Nov 8, 2005 | 07:35 AM
mgl's Avatar
mgl
for leds, you will need load resistors in order for it to blink normally.
https://my350z.com/forum/showthread....3&page=1&pp=20
check out page 4.
Old Nov 8, 2005 | 07:38 AM
pureZness's Avatar
pureZness
what is resistor?
Old Nov 8, 2005 | 07:50 AM
lemonjihwan
then do i need all 4 resistors for all 4 blinker? hope not....
is there any other way!?!?
Old Nov 8, 2005 | 06:40 PM
lemonjihwan
anybody know how to fix this problem?
Old Nov 8, 2005 | 07:40 PM
vkzawa's Avatar
vkzawa
All I know is that it WILL require resistors.
I have the same exact setup as you, in the front I have white LEDs and in the back I have red LEDs for the blinkers.
Mine blink really fast, but I haven't bothered with resistors because I like the sped up blinkers. You see I change lanes really fast and with the stock blinkers I would only get 1 or 2 blinks in before I was in the next lanes, so this effect is great, even though I didn't mean for it.
Old Nov 8, 2005 | 08:13 PM
pureZness's Avatar
pureZness
what is resistors?
Old Nov 8, 2005 | 08:16 PM
lemonjihwan
how hard is to install resistor? cuz all i need 1 pair for front.
Old Nov 9, 2005 | 08:26 AM
maxpowers's Avatar
maxpowers
I recommend you read through that post that MGL posted. You will get your answers there. The type of resistor you buy will depend on wether you want to run LEDs in both the front and back.
Old Nov 9, 2005 | 09:05 AM
ares's Avatar
ares
Veteran
you will need 1 resistor for every bulb. they simulate the load that a normal bulb would use. the car senses this; that hyper flash is its way of telling you a bulb is out. with an LED in there, the draw is so low it cant tell anything is there.
Old Nov 9, 2005 | 09:08 AM
vkzawa's Avatar
vkzawa
Hey ares. This is nothing wrong with running them in 'hyper flash mode' is there? I don't want resistors because I like the effect.
Old Nov 9, 2005 | 10:02 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Resistor:
$9 each from AutoLumination We need the 3 ohm ones.
Installation:
One is required for each side (2) total for the whole car. These guys get hot in use so don't touch them if you've had your blinker on and keep them away from other wires and plastic. I mounted mine to a piece of the bumper framing tightly to allow it to sink some heat into it.
Old Nov 9, 2005 | 06:05 PM
lemonjihwan
whatsup guys..?? some people telling me i need 4 resistors and PAUL350Z is telling me i need only 2 resistors for whole car.
to make this clear. im running LED both front and rear signals.
do i need 2 or 4!?!?!?
Old Nov 10, 2005 | 06:35 AM
maxpowers's Avatar
maxpowers
As posted in the thread link several posts up:
"You need a 6 ohm resistor for one bulb in the circuit - one resistor per side. If you replace both bulbs the 3 ohm resistor is used.
The six ohm resistor will draw 2 watts, the rear light bulb will draw 5 or 6 and the LED bulb in front will draw about 1 watt for a total of 8-9 watts and the sensors are happy.
The 3 ohm resistor will draw 4 watts, and the two LED bulbs will draw 2 watts for a total of 6 watts and the sensors are happy.
Old Nov 10, 2005 | 06:53 AM
abstrakt's Avatar
abstrakt
you will need 1 resistor for each bulb = 4
Old Nov 25, 2005 | 09:00 AM
lemonjihwan
I got everything working fine. Thanks guys.
Oh by the way, I only needed 2 resistors. i installed them on front. and rear turn signal works fine! so it wasnt 4 resistors that i needed.
anyways thanks
Old Nov 25, 2005 | 12:28 PM
steveiZdaman's Avatar
steveiZdaman
do u need the resistor if you put LEDs for the parking lights or they are plug and play?
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
