rolling the wheel wells...
Old Nov 8, 2005 | 12:07 PM
undRgrNd350z's Avatar
undRgrNd350z
Default rolling the wheel wells...
how hard is it and what should it cost?
Old Nov 8, 2005 | 12:20 PM
AZ350Z's Avatar
AZ350Z
You can do it yourself, I did it is easy. Use a wooden baseball bat and take your time. I left the car in the sun for an hour then jacked it up, took off the wheel and rolled the lip.
You will be suprised how thin the lip is and how easy it is to do.
Old Nov 8, 2005 | 12:25 PM
VO...'s Avatar
VO...
Administrator
The Z is beautifully designed car. Is having another 1 inch width of rear tire really worth it?
Old Nov 8, 2005 | 12:30 PM
350Z007's Avatar
350Z007
Or you can rent the tool that bolts to your lugs and does it right.
Old Nov 8, 2005 | 12:35 PM
bryants95240sx's Avatar
bryants95240sx
Its not hard you can do it with a base ballbat or rent the fender roller And a heat gun.
Old Nov 8, 2005 | 05:05 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
its easy to do badly..it's difficult to do it perfectly
Old Nov 10, 2005 | 04:37 AM
bmxox's Avatar
bmxox
what does this comment even mean? rolling the fenders just folds the metal edge of your fender up that would cut into the tire if you're too low and your wheels are too wide. its not even noticeable from the exterior of the car except the overall appearance looks 10x's better because you can fill have no wheel gap and not tear through your tires.
On another note, you can rent my fender roller. PM me for details.
Old Nov 10, 2005 | 06:25 AM
djnc's Avatar
djnc
+1...and how much would it cost to get a body shop to roll the fenders for you?...just curious
Old Nov 10, 2005 | 12:25 PM
bmxox's Avatar
bmxox
Depends on where you go. I doubt the average body shop will have a fender roller and any reputable shop wont use a bat. The lip could also be hammered up by a body shop but that would cost more due to paint/body work afterwards. A hotrod shop would be more likely to have a roller and more experience in my opinion. But if you take your time and do it right, it takes about 45 minutes to an hour per fender to do a good job without cracking the paint. So if they charge $50-100 an hour labor, it could be $2-400.
Again, anyone wants to rent a roller and heat gun, PM me.
Obadabot
Jun 18, 2023 11:31 PM
