HID conversion on BASE!
Old Nov 13, 2005 | 01:39 PM
Zexy's Avatar
Zexy
Exclamation HID conversion on BASE!
I have researched but there is no clear answer on what EXACTLY needs to be done for an HID converison onto the Z.
To start off i will be buying the Mcculloch kit:
http://cgi.ebay.com/ebaymotors/3000K...13500731QQrdZ1
-I'm looking for an H7 / D2R bulb correct?
-Is this STRAIGHT plug and play? No drilling, cutting etc. whatsoever?
-The bulb will fit the stock connecter on the headlight?
That's all i need to know, any help would be awesome.
Old Nov 13, 2005 | 05:03 PM
Zexy's Avatar
Zexy
Can somebody please help me???
Old Nov 13, 2005 | 05:13 PM
05-Z's Avatar
05-Z
I would ask the seller, or consider Jun's OEM kit.
Old Nov 13, 2005 | 05:21 PM
Zexy's Avatar
Zexy
^ He does not respond my emails so he loses my money.
PLEEEASSSEE!! I need help!!!
Old Nov 13, 2005 | 06:31 PM
guppies211's Avatar
guppies211
DO NOT BUY McCullochs. IT IS DIM. The OEM kit is better. Come to think of it, I'll sell u mine for cheap if you want. I have the 6k kit. Used for 2 weeks and took them out. POS. I got the OEM kit but the light pattern on the floor sucks. Gonna get the 06 housing and HIDS now.
Old Nov 13, 2005 | 06:54 PM
squall35's Avatar
squall35
ask Jun ...i have bought his kit and work perfectly...
Old Nov 13, 2005 | 07:20 PM
Sully's Avatar
Sully
IMO:
I bought the MeccaTune RED STAR kit, which has Hella Ballast. Its an 8300K kits, more blueish light. But in comparison to stock base Halogens, its about 95% better. 5000-6000k HID bulbs have the best output from what i read. But, my 8300k are PREFECT IMO.
What you will need?
The base Halogens are H7's, you will need a H7 retrofit kit. Try to go with a Hella Balast, and a Phillips bulbs. Like i said, ive had my MeccaTune Red Sun kit for almost 1 yr 1 month, without any fading, dimming, or lose of color/brightness.
I believe this is the guy i got it from:
http://cgi.ebay.com/ebaymotors/880-9...spagenameZWDVW
Now he offering 6000k which is nice.
Good luck
Sull
Old Nov 13, 2005 | 07:26 PM
Ztalker's Avatar
Ztalker
Any current aftermarket HID conversion kit should work with the Base Z headlight housing....i had my Base Z converted not too long ago and it is still working fine. It was a direct plug and play...hooks up directly to your existing H7 low beam plug for power. You need to find a place to adhere the ballast and the igniter. Some newer kits only come with the ballast and you don't need to find room for the igniter. i ordered mine from superhids.com and they ship overnight. My 5300k H7 is ultra white and you might have to adjust the headlights to get a better light pattern on the ground. BTW, you might have to drill a 3/4" hole on the plastic covers. Good luck and enjoy.
Old Nov 13, 2005 | 08:07 PM
Zexy's Avatar
Zexy
I have done research and have indeed concluded i should go for JUN's OEM HID kit but he does not respond my email
Old Nov 13, 2005 | 08:34 PM
jinsei888's Avatar
jinsei888
find jun, PM him
Old Nov 14, 2005 | 12:18 AM
jhp1025's Avatar
jhp1025
I installed the McCulloch 8000K HID Kit from ebay and they are the best. They do require a hole to be drilled in the plastic cover to run the wire out to the Ballast and Starter. And you will need to re aim them after the install. I have had four sets of these bulbs in different vehicles and think that they are the best.
Good luck.
Old Nov 14, 2005 | 01:12 AM
showstoppertk's Avatar
showstoppertk
speaking from someone stuck with an aftermarket HID kit that has crapped out and is only about 1 1/2 yrs old I strongly recommend figuring out a way to get ahold of Jun or just buying an OEM setup yourself.
Old Nov 14, 2005 | 05:23 AM
classic6's Avatar
classic6
try jlevisw.com when i used to have my bmw, i got all my lighting from him. he doesnt have the kit on his site but if you call him he will get it for you.
Old Nov 14, 2005 | 07:20 AM
drifter23's Avatar
drifter23
I have the McCulloch 6000k HID kit on my 2004 base 350Z for almost 2 years and they work great IMO. I have attached some pictures of the kit compared to the stock lighting below. And installation of these kits is plug and play except for the 3/4" hole drilled through the plastic headlight cover.
Attached Thumbnails HID conversion on BASE!-my-headllights-011.jpg   HID conversion on BASE!-my-headllights-012.jpg   HID conversion on BASE!-my-headllights-013.jpg   HID conversion on BASE!-my-headllights-006.jpg
Old Nov 14, 2005 | 07:27 AM
Zexy's Avatar
Zexy
I hear exceptional and bad things(bulbs/balasts blowing within a year) about the Mcculloch kit. Bottom line i do believe most of the time you get what you pay for and OEM reliability tops them all.
Old Nov 14, 2005 | 07:29 AM
Zexy's Avatar
Zexy
You're just too ****ing picky.
Pleask
Dec 21, 2021 03:17 PM
Dsowe
Feb 17, 2021 10:38 AM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
