What is this adjustment for?
Old Nov 17, 2005 | 10:32 PM
Gryphin's Avatar
Gryphin
Default What is this adjustment for?
if you notice there is a green X this is the height adjustment... but...
what is the adjustment before it under the cap?
Old Nov 17, 2005 | 11:01 PM
vkzawa's Avatar
vkzawa
Links don't work.
Old Nov 17, 2005 | 11:02 PM
vkzawa's Avatar
vkzawa
is there suppose to be something after image where the three ... are.
Old Nov 17, 2005 | 11:26 PM
Gryphin's Avatar
Gryphin
fixed
Old Nov 18, 2005 | 03:57 AM
DavesZ#3's Avatar
DavesZ#3
That represents a Philips head type adjuster for the headlight height adjustment. If you have a long #2 philips screwdriver, it will fit right into that opening and act as a driving gear for the teeth on that adjustment.
Those images came from Hypersprite's site. Here are his instructions for adjusting your headlight height....
http://www.hypersprite.com/auto/tech-z-003/index.asp
Old Nov 18, 2005 | 08:48 AM
Gryphin's Avatar
Gryphin
I know what the green arrow one is for... but what is the adjust went under the cap for?
Old Nov 18, 2005 | 11:44 AM
barthelb's Avatar
barthelb
Master
I think your talking about the same thing, those teeth or triangle medal pieces are the adjustment for the lights. There is nothing visible that is before that. The adjustment isn't under the teeth, the teeth are the adjustment.
Old Nov 18, 2005 | 01:31 PM
Gryphin's Avatar
Gryphin
i highlighted the part i was talking about, i know what the green arrow is, but if you pop that cap off there is another gear...
Old Nov 18, 2005 | 02:21 PM
DavesZ#3's Avatar
DavesZ#3
I just went out and looked at it on my car. I don't think it's an adjustment of any kind. It looks like it's a cover to an opening in the headlight housing. I don't really see a reference to it anywhere in the service manual in the section dealing with the headlights.
Old Nov 18, 2005 | 03:11 PM
Gryphin's Avatar
Gryphin
if you pop that cap off there is a gear there, i think its for the left to right... but im not sure i was just wondering if anyone has played it
Old Nov 18, 2005 | 04:43 PM
DavesZ#3's Avatar
DavesZ#3
I still must be looking at the wrong thing. The plastic cap I see would be next to impossible to remove in it's normal mounted position. I'll try to look tomorrow when the sun's up but you're probably right, there must be some L/R adjustment for it.
Old Nov 18, 2005 | 05:01 PM
Gryphin's Avatar
Gryphin
if you use a flat hear screw driver, and push on that little tab towards the rear of the car it will pop off, exposing a gear
Old Nov 18, 2005 | 05:10 PM
TruBluZ's Avatar
TruBluZ
Just turn it and see what it does. If nothing happens, keep turning it until something does happen. Then let us know what it does.
Old Nov 18, 2005 | 05:27 PM
Gryphin's Avatar
Gryphin
lmao i did mess with it just a second ago, its the left to right i believe.. didnt have a flat wall to work with... gargage door isnt level with ground... so it looked like it was moving at an angle
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
