Sequential Rear LED Turn Signal Retro
Old Apr 18, 2006 | 11:31 PM
  #141
creationv2's Avatar
creationv2
oh also in the process in which you stated, does that mean the housing in which the buyer recieves will be that of the last person? if so does the condition of the housings not bother you, as one may be more damaged than anohters?
Old Apr 18, 2006 | 11:53 PM
  #142
Acree's Avatar
Acree
Good questions. The group buy will end 4 weeks after the original start date. Since I currently have finals to attend to in the next 2 weeks, it looks like the start date may be pushed to the second week in May. Regardless, it will end 4 weeks after the starting date.
As far as housing condition is concerned, yes that is an issue that will be addressed in the following manner. Whenever someone places an order for what ever configuration they wish, on top of the posted price, they will also need to place a deposit of $160. I will hold this deposit until I receive their housings. I will thoroughly clean and inspect both housings. After I have confirmed the housings are undamaged and acceptable, I will refund the deposit in full. If one wishes, they can just pay $160 for completely new housings. This price is not inflated, and is exactly the same as one would pay for a set of brand new housings with wiring harnesses included. I see this as the best way to handle the housing issue.
If there is any issue with a customer's housing, I will take it up with them through phone or private messages. If we can not both come to an agreement about how to handle the situation, then I will simply return the housings to them, and keep the deposit to purchase a new set.
Feel free to ask any more questions.
-Acree
Old Apr 19, 2006 | 05:11 AM
  #143
HockeyZ39's Avatar
HockeyZ39
Originally Posted by Acree
It does have to come all the way off. Here's a few basic steps:
1. Take out both tail light assemblies.
2. With a 10mm socket and atleast a 2" extension, take off the bolt that was under the tail light assembly. You will see it if you get down lower and look in the bottom corner. One on each side.
3. Unscrew one bolt on each bottom side of the bumper.
4. Unscrew one bolt on each side inside the fender well.
5. Get under the car and pop out the 2 retaining thingies.
6. Pull the passenger side out a little ways until you see the last retaining clip.
7. Put a small flathead screw drivers under the retaining clip between the body and the clip, NOT the bumper and the clip. There will be a clipping mechanism on opposing sides of the clip, so you need to push each one into the clip while pulling it out. Once you push in both sides, it will come out of the body.
8. CAREFULLY - Pull at the top part of the bumper between the 2 tail lights to pop lose the retaining clips.
9. Do the same to the clip on the driver's side.
10. Optional - Undo the wiring harness for the license plate lights, and both turn signal assemblies. You can take both turn signal assemblies out without unclipping the wiring harness from the license plate lights and leaving the bumper somewhat attached to the car.
11. On each housing, there are only 2 philips head screws on each side. Unscrew them and the housing will come out.
I will have a full step by step instruction set with pictures and steps that will ship with the turn signals. Hope this helps Hockey.
-Acree
Thanks as always Acree
Old Apr 19, 2006 | 12:37 PM
  #144
creationv2's Avatar
creationv2
awesome thanks for the answers acree....seems like a good and fair process....i think this is my last questions....model year should not matter right? as of now theyre all basically the same right? as in fitament, harnesses, etc?
how fast is the estimated turnover?
im not sure if acree would know this....but if anyone in socal can shed some light on whether lights like these would be illegal? jw cuz they are kind of distracting...
Old Apr 19, 2006 | 12:54 PM
  #145
Acree's Avatar
Acree
Fitment, yes these will fit on any Z, 03-06. Everything will be strictly plug and play. Assuming I have a new set of housings on hand waiting to be converted, I will be able to complete a full set in 2-3 days.
-Acree
Old Apr 19, 2006 | 01:27 PM
  #146
creationv2's Avatar
creationv2
youre the man acree thank you for answering all my questions
Old Apr 19, 2006 | 01:34 PM
  #147
Acree's Avatar
Acree
NP man.
-Acree
Old Apr 20, 2006 | 02:45 PM
  #148
A06ZRT's Avatar
A06ZRT
i love this idea... now i must get them for my zr... how much? $520 + $160 for housing?
Old May 21, 2006 | 10:26 PM
  #149
lilaznxboi08's Avatar
lilaznxboi08
dang this guy is nutsssss
Old May 21, 2006 | 10:54 PM
  #150
Acree's Avatar
Acree
Thanks.
-Acree
Old Jun 10, 2006 | 06:54 AM
  #151
bghoward's Avatar
bghoward
Just FYI courtesyparts.com sells the housing alone w/out the light bulbs for 54.99 each. That makes it much cheaper than the $160 a pair price.
http://www.courtesyparts.com/Merchan...de=26559-REVRS
http://www.courtesyparts.com/Merchan...de=26554-REVRS
Old Jun 10, 2006 | 07:56 AM
  #152
Acree's Avatar
Acree
Ah good point BUT, for this conversion I have to use the housing with the harness. Those are $62.63 a piece. So once I buy 2 of them, I am looking at $125.26. Then once I add $10-15 bucks of shipping, I figured the extra $15-20 was more than fair for my time and effort in ordering new housings. I have been looking into using an aftermarket housing from ebay that has a completely clear housing. These housings are around $100 bucks. I might decide to offer these also.
Old Jun 10, 2006 | 08:29 AM
  #153
HockeyZ39's Avatar
HockeyZ39
I have just been trying to find a used set on eBay! and no damn luck, if there ever is a pair me and acree will have a bid war on it! haha
Old Jun 12, 2006 | 07:12 AM
  #154
zigggy56's Avatar
zigggy56
Found these on E-bay, however Don't think they will work well for this application.
http://cgi.ebay.com/ebaymotors/04-05...72749788QQrdZ1
http://cgi.ebay.com/ebaymotors/03-06...3680QQrdZ1#des
http://cgi.ebay.com/ebaymotors/03-06...74758457QQrdZ1
Attached Thumbnails Sequential Rear LED Turn Signal Retro-1138011356975_dscn0615.jpg   Sequential Rear LED Turn Signal Retro-lb_n350z03er_dp_sb.jpg   Sequential Rear LED Turn Signal Retro-1140962012998_03_06_350z_bul_clear.jpg
Old Jun 14, 2006 | 05:18 AM
  #155
HockeyZ39's Avatar
HockeyZ39
Ya I have seen them, I am sure they could work, but I just want a used cheap set!
Old Jun 15, 2006 | 06:02 AM
  #156
zigggy56's Avatar
zigggy56
acree - Question nobody else on here has thought of... What is the flash pattern when you set the alarm throught the remote KeyFOB?
Old Jun 15, 2006 | 06:14 AM
  #157
Acree's Avatar
Acree
When you unlock the car, the flash pattern is pretty much the same length as a normal turn signal period. When you lock the car, the car sends a signal that is exactly half of the unlock period. So, 5 out of the 9 segments light up, twice.
If your Z doesn't turn the signals on when you unlock the car, and does NOT honk when you lock it, hold down lock and unlock at the same time while you are near the car. This will change the mode to flash when unlocked, and flash/honk when locked. To change it back to the more quiet, lock only flash mode, just hold them down again.
-Acree
Old Jun 16, 2006 | 01:33 PM
  #158
trescincuenta's Avatar
trescincuenta
OMG acree I searched all over for that because since day 1 my car never honked when arming and not event he manual says how to change it. Youre the man!
Old Jun 16, 2006 | 01:57 PM
  #159
Acree's Avatar
Acree
Very rarely do I laugh out loud while reading the forums, but that did it! I'm glad I could help man.
-Acree
Old Jun 16, 2006 | 02:08 PM
  #160
HockeyZ39's Avatar
HockeyZ39
^^^ hahahaha I figured it out from this forum also, and the window down button as well.
