Removing Dealer Badging
Old Jan 8, 2006 | 08:15 PM
ZROCKET's Avatar
ZROCKET
Default Removing Dealer Badging
I want to remove the dealer badge from the rear of the car, without damaging the paint. It's a thin metal badge, most likely stuck on with a adhesive backing. I was thinking of heating the badge up with a heat gun and carefully removing it. What do you think?
Old Jan 8, 2006 | 08:51 PM
Mike Wazowski's Avatar
Mike Wazowski
heat it up is fine and then use dental floss. The dental floss is coated and will not hurt your paint. It is also so small it fits between the badge and the body of the car no problem. Use a little adhesive remover to get rid of the goo and touch it up with a little cleaner and wax and your set.
Old Jan 8, 2006 | 08:55 PM
Vamos_Rafael's Avatar
Vamos_Rafael
+1 wax and polish afterwards
and btw heat it with hair dryer on med
Old Jan 8, 2006 | 09:07 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
Vegas does that silly Stealer badging???? I thought that was more on the east coast than as close as Nevada....Sucks
Old Jan 8, 2006 | 10:21 PM
m0nkie's Avatar
m0nkie
i used a hair dryer.. heat it for a few min. used my nails and got it off no problem.. no scratch, nothing.. as for the left over adhesive.. some nice rubbing on it for a few min will get it right off..
Old Jan 9, 2006 | 08:10 AM
Roggan's Avatar
Roggan
Smart idea with the dental floss, ill try with that when im fitting my Fairlaidy Z badge where the 350Z badge is from factory.
/Roger
Old Jan 10, 2006 | 08:51 PM
Jason021174's Avatar
Jason021174
make their azz remove it. they put it on, they can take it off! dealers suck salty *****.
Old Jan 10, 2006 | 09:08 PM
meezie's Avatar
meezie
Use Goo-Gone for the after affects of the sticky adhesive. I used it when I swapped for the Fairlady Z emblem; worked just great.
Old Jan 10, 2006 | 10:59 PM
JDMFairlady21's Avatar
JDMFairlady21
def need to try this when i put on the fairladyZ badge.
Pleask
Dec 21, 2021 03:17 PM
07ZEKE
Aug 23, 2021 09:15 PM
ablaine
Nov 29, 2016 10:13 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
