side markers
Old Jan 25, 2006 | 01:10 PM
  #41
boogiemyke's Avatar
boogiemyke
They may work. They look pretty much the same and like they "should", but noone has confirmed yet.
Mike
Old Jan 30, 2006 | 05:19 PM
  #42
amacahilig's Avatar
amacahilig
did anyone try to fit those honda sockets?
Old Feb 1, 2006 | 12:59 PM
  #43
amacahilig's Avatar
amacahilig
hey guys, i found this on ebay. you this the socket would fit?
http://cgi.ebay.com/ebaymotors/INFIN...33425743QQrdZ1
Old Feb 10, 2006 | 04:15 PM
  #44
streetd's Avatar
streetd
Hey I had a friend that works at a body shop and he had a couple of rubber sockets, we just cut of what we didnt need and used that. It works perfectly.
Old Feb 10, 2006 | 04:17 PM
  #45
streetd's Avatar
streetd
and before anyone says anything it was wet out and I just got off the interstate.
Old Oct 1, 2006 | 08:20 AM
  #46
djlynch's Avatar
djlynch
Bump....
how did this ever turn out? are those still available thru mynismo.com? followed the links but couldnt find anything.. also, on mynismo there is a sidemarker harness .. is this of any use?
Im wanting to do this also, but looking for a complete kit, or something not so diy... any suggestions or new ideas on the sidemarkers?
Old Oct 1, 2006 | 03:06 PM
  #47
esfand's Avatar
esfand
Originally Posted by Z_Driver
Is this what you are looking for? If so they are LED's embedded into a plastic ring:
If this is what you are talking about. These are drilled in three places for LED's and mounted from the rear with epoxy:
where did you get the ring that goes behind the Z????
thanks
Old Oct 1, 2006 | 09:17 PM
  #48
Panda350z's Avatar
Panda350z
Where can i buy the JDM side markers? Everywhere I look they are sold out!
Old Nov 7, 2006 | 05:14 PM
  #49
flipknoc's Avatar
flipknoc
Panda350, I just got mine this week from this guy at ebay: carbeyondstore. It shipped quick.
Can someone confirm if this harness works:
http://performancenissanparts.com/products/?id=5306
And for anyone that got their's installed, how much did you pay? I got a couple of quotes for $150 in SoCal. Help. Thanks.
Old Nov 7, 2006 | 05:36 PM
  #50
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
that is the harness connector, not the actual bulb / socket... its the socket that goes into the side markers that is the problem to find... it is included only with the full body harness on the JDM Z33
Old Nov 7, 2006 | 06:41 PM
  #51
jdm_350's Avatar
jdm_350
you mean these side markers? I just used the harness from a nissan titan.i know some one at nissan and he had some in an old parts box i test fitted them and you have to modify it a little but it works and seals the light bulb so i doesn't leak in water.hope this helps
Old Nov 7, 2006 | 08:05 PM
  #52
Jason@Performance
Performance Nissan
ill have the parts guys check the harness off the titan...
Old Nov 10, 2008 | 07:41 PM
  #53
Kwame's Avatar
Kwame
Bump!
Anyone find a direct fit socket for these lights yet? I much rather just install these instead of glassing over the hole allotted for these in my ings fenders.
Thanks in advance.
Old Nov 11, 2008 | 07:52 AM
  #54
Done Deal DR's Avatar
Done Deal DR
I would have to imagine all that is needed it to splice into the turn signal wiring in the headlight and run the wire back to your fender turn signal you are installing. Otherwise it will be slightly more complicated wiring into the the steering rack where the turn signal lever is. Other people with more experience can chime in...but that seems the easiest to me with my limited EET experience.
Old Nov 11, 2008 | 08:19 AM
  #55
Kwame's Avatar
Kwame
Thanks for the response (at least I think you are responding to me). My problem doesn't lye in figuring out how to wire in the side indicator harness into my existing turn signals, my problem is in trying to obtain the actual harness and bulb socket for the fender side indicators. I think I may have found something comparable so we shall see.
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
