Cheapest 06 led taillights???
Old Feb 15, 2006 | 05:12 PM
dkny_boi's Avatar
dkny_boi
Originally Posted by mgl
hmmm.... my turn signals light up, not my taillights.
Must be aftermarket alarm? I know my stock alarm is the signals... I've had other car with aftermarket and the blink the parking lights/brakes.
Old Feb 16, 2006 | 07:40 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
on my 03 my brake lights flashed...
on tony's 04 only his signals flased...
who knows...
I was happy
Old Feb 16, 2006 | 09:39 AM
mgl's Avatar
mgl
who knows...
I was happy
weird... mines an '03 and my signals flash.
do your headlights flash too? or just front turn signals?
Old Feb 16, 2006 | 01:06 PM
BlueBlur's Avatar
BlueBlur
Is this a difficult install between the older lights & the new LED lights?
Old Feb 16, 2006 | 02:22 PM
2 low Z's Avatar
2 low Z
Originally Posted by davidf
I actually popped the cap off the back and disconnected the black/silver wire that lights the little corner light on the side and it looks much better at night.
Pics?
Also is there a way to wire the tail lights to the turn signals so they would work normal and flash left or right when turning? I would disconnect the amber ones.
Old Feb 16, 2006 | 06:44 PM
Jason@Performance
Performance Nissan
just the running lights flashed...
is your 03 an HID?
I had a performance model...
Maybe it was the way I set the remote? You know how you can make it silent, long or short horn etc...
hrmm....
Old Feb 16, 2006 | 06:46 PM
dkny_boi's Avatar
dkny_boi
I wonder if that procedure was different in the 03 models to the 04's. The manual for my 04.5 lists two methods... one method blinks the hazards and beeps the horn, and the other method blinks the hazards but no horn sounds when you arm it.
Old Feb 16, 2006 | 06:55 PM
2 low Z's Avatar
2 low Z
Probably the alarm, my 05 flashed the turns when stock, flashes the tails with my Clifford alarm. Some alarms you can change the settings. As far as headlights, caution if you have HIDs do not set them to flash with your alarm. It will cause your bulbs to burn out prematurely. You should wait about 5 min. when you turn them on to turning them off. This is why on HID; high beams are usually a different halogen bulb (comes on and the low HID bulb stays on) or it has a lens that slides in front of the beam for high beam. (like the 06)
Old Feb 16, 2006 | 08:29 PM
Jason@Performance
Performance Nissan
I didnt have an aftermarket alarm.. just the factory keyless entry...
Juztin
Nov 22, 2015 07:03 AM
Mw870
Oct 2, 2015 08:23 AM
350z82
Oct 1, 2015 06:25 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
PureR3d
Sep 10, 2015 06:23 PM
