question about lowering and headlights
Old Apr 12, 2006 | 08:43 PM
LiLxDooD's Avatar
LiLxDooD
Default question about lowering and headlights
Hey guys,i was just wondeing. If you lower your car, do you have to adjust your headlight bulb up to it makes up for the drop? After lowering my car, i feel like alot of my light is on the ground and not enough out.
Old Apr 12, 2006 | 08:54 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
i didn't. However, if you want, go here:
http://www.hypersprite.com/z/auto/default.htm
check under: Headlight adjustment for the 350Z
Old Apr 12, 2006 | 09:49 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
This shouldn't be a problem unless you lowered the front a lot more than the rear.
Old Apr 12, 2006 | 10:52 PM
Selski12's Avatar
Selski12
On oem springs, the headlight beam was already low on mine (I can only see from about 2 car lengths). I readjusted after lowering and now can see atleast 5+ car lengths ahead. I followed the instructions on HyperSprite.
After lowering the hottest spot was at around 23.5" from the ground. I went with the hypersprites 27.5" and there is a huge difference at night.
Old Apr 13, 2006 | 08:40 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
I have been meaning to add this to the web page but I need to get some measurements of a stock ride hight car.
If the car is lowered, reduce the 27.5" by at least as much as its lowered.
Example: If the headlights are 1" closer to the ground, try 26.5".
Otherwise what happens is they start angeling upward and although it's only 27.5" at 8' feet, it could end up much higher at fifty to one hundred feet and and dazzling oncoming drivers is not a good thing.
Chris
Old Apr 13, 2006 | 10:27 AM
cellphoneguy's Avatar
cellphoneguy
man, i can't see $hit. Where the hell is that gear at!
Old Apr 13, 2006 | 11:22 AM
LiLxDooD's Avatar
LiLxDooD
yea, i think i really needa do mine too, imma do it tonight.
Old Apr 13, 2006 | 11:25 AM
LiLxDooD's Avatar
LiLxDooD
is it 8 ft from the wall? or 8 inches?
Old Apr 13, 2006 | 04:28 PM
LiLxDooD's Avatar
LiLxDooD
Old Apr 13, 2006 | 04:41 PM
TiPIACE's Avatar
TiPIACE
yeap i had to adjust the headlights after my Tanabe NF210 drop
i put a long philips screw driver down the headlight into that toothed wheel and was turning for hours without being able the rotate the wheel
i wrapped some masking tape around the tip of the screwdriver to make it thicker/grippier, and the toothed wheel now likes to turn for me
Old Apr 14, 2006 | 12:47 PM
LiLxDooD's Avatar
LiLxDooD
I think its 8 ft right? not inches?
Old Apr 14, 2006 | 12:50 PM
BhashaZ's Avatar
BhashaZ
Feet.
Uriyo_
Sep 8, 2021 08:46 AM
JGee450
Sep 30, 2015 04:32 AM
