Installing clear side markers
Old Apr 21, 2006 | 01:41 AM
MajorWoody's Avatar
MajorWoody
Default Installing clear side markers
Since the "search" functions isn't working for me, I have a question to ask. I bought a set of clear side markers for my 04 350Z and would like to know if these can be installed without removing the bumper and all that crap?
Thanks in advance.
Old Apr 21, 2006 | 03:36 AM
vantage350z's Avatar
vantage350z
Ya, just jack up the car, put some jack stand on both sides. Then remove the bottom skid plate as if you were changing the oil. You will be able to access the side markers from the bottom. little tight in there but alot faster than removing the bumper...
Old Apr 21, 2006 | 03:55 AM
vincentalunni's Avatar
vincentalunni
Just did it last night I found that on the right hand side ( passenger ) is obstructed with the window washer tank was in the way. Just remove the front right tire and take out part of the passenger side bumper so you can pull the bumper far enough away from the car to make the job go a little easier.
Old Apr 21, 2006 | 04:01 AM
MajorWoody's Avatar
MajorWoody
Thanks to you two
Old Apr 21, 2006 | 06:56 PM
jwales's Avatar
jwales
I did this last week and worked fine with front bumper and tires still on. Just had to buy a small "Z" shaped screw driver from AutoZone for $5.
hulkout
Apr 28, 2017 09:00 PM
kyin
Oct 15, 2015 05:54 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
