How do i change my parking light for my Z?
How do i change my parking light in the headlights for my Z, anybody?
beacause it looks a lot confusing when i opened my hood...i thought it was going to be easy but...you have to remove a lot of things before changing it! DAMNMET!!!
You have to remove the front wheels and you go in from behind via the wheel wells.
This thread ought to get you started.
https://my350z.com/forum/exterior-and-interior/128023-front-led-turn-indicators-w-resistor-56k-warning.html
You cannot change the front parking lights from the top by opening the hood.
However, I can do it without removing the front wheels.
You need to first turn your wheel all the way to one side, then undo 2 screws along the edge of the inner fender, then 3 clips holding the the inner fender behind the headlight.
Note, you will need to jack up your car with the jack in the trunk to be able to remove 3 clips and have enough space to undo the screws with a short screw driver.
I changed the front turn signal, parking lights and the bumper amber marker all togther. Is not difficult.
Good luck.
Good luck.
sorry for bugging all you guys but im just a girl with a Z and i dont know too much about parts and stuff...but does anybody know the type or size or part number of the parking light bulb and the main headlight bulb because i want to buy the bulbs first then install it on instead of removing the bulbs and bringing it to the store to show them...please anybody!!!
Originally Posted by Paul350Z
Check your state laws about what colors are permitted in the turn signals.
They make chrome colored yellow lights. They look silver when off and blink yellow.
