PICS of my front license plate mounting
Old Feb 12, 2003 | 03:51 PM
JeremyL's Avatar
JeremyL
Default PICS of my front license plate mounting
I got my plates last night and decided to try my own mounting method before going and spending $50 on a kit.
Hires pics at http://www.laurenson.com/users/jeremy/350z
Heres what I got:
I used the front bracket that comes witht he Z and trimmed off the buldge with a pair of good scissors and a bread knife.. (All the right tools, baby!)
I used the scissors to make two additional holes in the bracket (as seen in the ziptie photo below) and ziptied the bracket to the top grill piece.
The bracket does not touch any paint as is.
I then hotglued two eracer nibs onto the bottom of the license plate and also put a thick amount on the bottom because the plate and frame mounting DOES touch the bottom lip on the paint and I would expect it would be mobile since I havent ziptied the bottom...
I also have a 3m shield on the bottom, so Im not worried about the movement unless it rattles - I'll let you all know.
1: Supplies
JeremyL's Avatar
JeremyL
Trimming the plastic mounting kit
Old Feb 12, 2003 | 03:52 PM
JeremyL's Avatar
JeremyL
Ziptied to the grill.
Old Feb 12, 2003 | 03:53 PM
JeremyL's Avatar
JeremyL
Plenty of space at the bottom without the plate
JeremyL's Avatar
JeremyL
But the plate is long and will touch the paint below.
Old Feb 12, 2003 | 03:54 PM
JeremyL's Avatar
JeremyL
So we bust ou the hotglue and the eraset tops!
Old Feb 12, 2003 | 03:55 PM
JeremyL's Avatar
JeremyL
The plate would otherwise touch the paint on the bottom of the scoop.
Old Feb 12, 2003 | 03:58 PM
JeremyL's Avatar
JeremyL
Voila!
I will report on rattles etc, though I dont expect any.. also H ave a friend making a real bracket to screw into the tow hitch location.
Old Feb 14, 2003 | 09:33 PM
03_Daytona350Z's Avatar
03_Daytona350Z
I was thinking about using zip-ties to mount my front plate to the grille. Will this cause any harm (decreased airflow to the engine?)
Old Feb 15, 2003 | 05:13 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
It will block the outside temperature sensor, so it will not be accurate. I have noticed 5degrees or more difference when I mounted my front plate by the airdam.
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
