Top Secret CF rear diffuser (pics)
Old Sep 23, 2006 | 04:01 PM
  #201
whitebwoy's Avatar
whitebwoy
Okay, this has nothing to do with what he just said, but I am curious.
Any of you guys with the diffuser plan on cutting a small (insignificant hole) near the rear of the diffuser (or rather the section under the car), for water to escape and small pebbles? or you don't give a crap about that stuff?
Also, the pan looks awefully close to the diffuser, wouldn't it be wise to just cut a smooth semi circle where the pan is so the diffuser doesn't get burnt.
And lastly - am I just being 'nit-picky', the damn thing will be fine. Every now and then just use a pressure hose and blow out anything that collects in there? lol.
Persoanlly, if I do get this thing, I am goin to cut a small (less than an inch) groove right at the lowest pooint i the centre of the diffuser to let water get out, and small pebbles.
Old Sep 25, 2006 | 12:41 AM
  #202
alshawi's Avatar
alshawi
Default Top secret rear diffuser semi-installed
I just got the chance to visit my car at the body shop, the side skirts are being painted at the moment and will be installed tom morning. The front bumper was already cut for the installation of the varis airduct and the front diffuser should be installed tom as well. Im just waiting for my exhaust to be ready cos i made custom piping in order for the rear diffuser to fit exactly how it should.
Chebesto: The dude that installed the bumper found out exactly where the backets go. PM and ill send u pics.
The Dude
left side bracket, hope it helps
Old Sep 25, 2006 | 03:45 AM
  #203
gringott's Avatar
gringott
Excellent pictures. Thank you.
Old Sep 25, 2006 | 08:46 AM
  #204
Chebosto's Avatar
Chebosto
awesome picts alshawi!! thanks!!!
Old Sep 25, 2006 | 09:10 AM
  #205
whitebwoy's Avatar
whitebwoy
alshawi - I know you said its not fully installed in those pics, but regarding the last pic, the main peice - when it comes back up to meet the bumper on each side, does it not fit flush? It doesn't look that way in the picture, which is why I am asking? Or was it just loosely bolted up for when you get the exhaust?
Old Sep 25, 2006 | 09:39 AM
  #206
Chebosto's Avatar
Chebosto
from my test fits. the rear piece is to almost sit flush/ kiss the rear bumper.. there was a slight gap on the sides....
Old Sep 25, 2006 | 11:16 AM
  #207
alshawi's Avatar
alshawi
yep, exactly what chebesto said, but yeah it was only loosely bolted up..
Im gonna post pics of exactly where it sits right after i finish the installation. The body shop just called me and said that the front top secret diffuser and varis airduct are already installed. So i guess im gonna take my car to the exhaust shop in a day or two for final installation. ill keep u guys posted
Old Sep 25, 2006 | 11:40 AM
  #208
whitebwoy's Avatar
whitebwoy
Can't wait to see it on completely installed and off the jacks.
Make sure you take every conceivable angle shot of this, PLEEEZ!!! LOL.
Old Sep 25, 2006 | 03:43 PM
  #209
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
The Dude
Those are cool socks!
Old Sep 27, 2006 | 02:04 AM
  #210
alshawi's Avatar
alshawi
Brackets
Left Side
Right side
sorry chebesto, deleted the PM by mistake, lost the email
Old Sep 27, 2006 | 05:41 AM
  #211
Silo's Avatar
Silo
At the end I would like to see ONE picture of the installed part taken from straight under the car (lift required however).
Old Sep 27, 2006 | 06:53 AM
  #212
whitebwoy's Avatar
whitebwoy
Those brackets look as though they get in the way of the exhaust pan/piping
Old Sep 27, 2006 | 07:16 AM
  #213
jinsei888's Avatar
jinsei888
not really
the top secret rear diffuser was designed for the Top Secret exhaust in mind, only. The dual tip Ti Top Secret exhaust is like OEM style where the muffler is all lateral contained within that diffuser tub. It is not meant for true dual....but I've never put this diffuser on, so only the current users know for sure.
Old Sep 27, 2006 | 08:01 AM
  #214
whitebwoy's Avatar
whitebwoy
Oh, so if you have the GREDDY TT, you can't have those brackets? Maybe just have to make some custom brackets in that case.
Old Sep 27, 2006 | 10:11 AM
  #215
Chebosto's Avatar
Chebosto
from the looks of alshawi's picts...
i'm gonna have to custom make the passenger side brackets...
also.. i'd put the brackets on the inside of the diffuser if i could... but i havent actually put it on the lift to see yet-
Old Sep 27, 2006 | 10:17 AM
  #216
gringott's Avatar
gringott
I am getting dizzy from looking at these pictures.
Old Sep 27, 2006 | 11:53 AM
  #217
davidf's Avatar
davidf
Very cool lic. plate.
Old Sep 27, 2006 | 11:56 AM
  #218
davidf's Avatar
davidf
Originally Posted by Chebosto
the arrows your drew are ontop of the diffuser- majority of the airflow will be flowing on the other side...(smooth side)
given the shape of our rear suspension / diff/ and exhaust piping layout, (and more importantly, the flat covers that are right before the rear suspension) majority of the air coming from the front of car will be flowing much lower to the ground... red circles are the flat panels designed to channel air down away from the rear suspension..
It is true that there will be some air that gets caught above the diffuser, but in theory..with the shape of the venturi channel lower toward the bottom of the car, at around the point where air will most likely be coming off the rear beam/differential, the air flow will be much faster, such that the effect of air that gets caught onto of the top portion of the diffuser will be negated...
also with the shape of the leading edge of the diffuser, the part that bends up,
will prevent air from going up there... however the should have done a better job and made that lip portion taller IMHO.. the whole premise is to seal off the rear bumper.. since alot of people are running after market exhausts and we're losing our natural diffuser (stock exhaust)
Is know thats a nismo diff. cover but us that a finned differential also?
Old Sep 27, 2006 | 12:42 PM
  #219
alshawi's Avatar
alshawi
the brackets should not get in the way of the greddy evoTT piping. They are placed very far back. But brackets dont need alot of work to be adjusted
Old Sep 27, 2006 | 03:36 PM
  #220
whitebwoy's Avatar
whitebwoy
Is the diffuser flexible, like how cf usually is. Or is it very rigid, and almost brittle.
I assume its flexible. I'm just asking, case I assme it'll be getting a little nudge here and there from daily driving/parking, etc.
It should be able to handle slight nudges and scrapes, right?
