About to replace emblems
Old Sep 8, 2006 | 03:40 PM
ZlleH's Avatar
ZlleH
Default About to replace emblems
I'm about to replace the stock rear and front emblems. I'm going out right now to get goo-gone to clean the stuff underneath the emblem.
So far from the research I have done on this site:
-Use a hairdryer to heat the old emblem
-Use some kind of plastic spoon to get part of the emblems edge up
-Use some kind of fishing string to get the rest of the emblem off. (Is it possible to use floss string instead?)
-Use Goo-gone to clean the area
I'm doing this at night and it will be raining all weekend long so I can't do that trick were you leave the car in the sun all day so you don't need to use a hairdryer. With that said, is there anything I am missing before I start this mod when I get back home?
Thanks.
Old Sep 8, 2006 | 04:42 PM
Takfire's Avatar
Takfire
Sounds like you got it.
Make sure to take your time and let the Goo Gone do the work.
Tak
Old Sep 8, 2006 | 06:33 PM
ZlleH's Avatar
ZlleH
Update:
-Dental floss is not a good replacement for fishing line. Luckily, I found some fishing line.
-Do not use a plastic spoon, worthless and can damage paint, go with fishing line.
-Hairdryer really helped.
-goo-gone felt like it didn't do anything to help out this process, I used soap and water and it basically did the same thing if not better.
Old Sep 8, 2006 | 07:42 PM
buffmanjeff's Avatar
buffmanjeff
cool, before and after pics?
Old Sep 8, 2006 | 07:58 PM
MUZZY's Avatar
MUZZY
i use an all purpose cleaner instead of goo gone. and i dont know if this helps but dental flase worked for me
Old Sep 8, 2006 | 08:58 PM
ZlleH's Avatar
ZlleH
I didn't take any "before" pictures but I think we can guess what it looks like. I've attached "after" pictures though.
I think I might order the "FairladyZ" emblem. There is a small scratch on the passenger side. it's minor but it's bugging me, so I figure I'm going to remove the driver side "350Z" emblem and put the "FairladyZ" emblem over the scratch on the passenger side
I ordered the satin finish emblem to match the 350Z and the door handle finish.
On a side note, I notice with this emblems, they are identical to each other. But I noticed that the OEM ones, the front emblem is just a bit smaller in hieght then these aftermarket emblem. I guess they were too lazy to make two molds or they didn't study the two OEM emblem to notice the slight hieght difference.
Attached Thumbnails About to replace emblems-emblem01.jpg   About to replace emblems-emblem02.jpg   About to replace emblems-emblem03.jpg   About to replace emblems-emblem04.jpg   About to replace emblems-emblem05.jpg
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
pr_350z
Oct 1, 2015 05:03 PM
