Headlights not flush?
Old Sep 8, 2006 | 06:42 PM
dosu350's Avatar
dosu350
Default Headlights not flush?
I noticed the front headlights have a gap at the bottem of them, one more then the other, is there a way to make my light go forward? or fix the bumper? even though the bumper is flush where its connected to the side panels, so im not sure why theres a gap
Old Sep 8, 2006 | 06:56 PM
Slopoke's Avatar
Slopoke
funny i noticed that on my 04 as well. curious why its like that....will be watching this thread...
Old Sep 8, 2006 | 07:00 PM
zz350zz's Avatar
zz350zz
You can adjust your headlights by loosening up the four bolts that hold it on and move it around....if that doesn't work....idk
Old Sep 9, 2006 | 02:21 AM
esfand's Avatar
esfand
my 06 is the same
Old Sep 9, 2006 | 05:19 AM
dosu350's Avatar
dosu350
both lights are the same? one of mine has like a 2 cm gap from the bumper and the other is like 1cm
Old Sep 9, 2006 | 06:58 AM
jinsei888's Avatar
jinsei888
shotty craftsmanship when building the car? mine is like that too
Old Sep 9, 2006 | 07:11 AM
dedmoonstears's Avatar
dedmoonstears
Default same here
complained about it ...dealeship didnt do anything, had a 03 that wasnt crooked like my current z
Old Sep 9, 2006 | 07:14 AM
Eazzy's Avatar
Eazzy
Have to see a pic --but I take front ends and headlites apart all the time. Is it possible that the bumper could be pulled back to close the gap ?--Its really just a question of taking everything apart and shimming/bending brackets etc til u get a good fit ---Takes a little time. On mine I had to shim the rear of the lights to make them even with the fender.
Anytime u have a really light weight car ur going to have to play with it because all the bracketing etc is bare minimum. Hate to say ---But use ur imagination
Old Sep 9, 2006 | 07:20 AM
IGotA350Z's Avatar
IGotA350Z
I haven't noticed the bumper and the spacing that you guys mentioned, but my car's lights when shined on the road are crooked. The right beam goes higher and longer just a little more than the left. Does anyone else see the same?
Old Sep 9, 2006 | 07:31 AM
Eazzy's Avatar
Eazzy
To both of u Guys ---First get it so u like the appearance----Then do a search ---There is a post here somewhere as to how to adjust ur lights
Old Sep 9, 2006 | 07:42 AM
dosu350's Avatar
dosu350
Okay ill try to adjust them, if that doesnt work how hard is it to remove and put the bumper back? never done one before
Old Sep 9, 2006 | 07:50 AM
Eazzy's Avatar
Eazzy
Little time comsuming but no big deal---Raise the car, Take off the wheels, Remove the Inner front wheel wells (Plastic) Drop the front of the plastic cover underneath the car, Pop out the retaining Buttons that are just under the hood that hold the top of the bumper, There are 2 screws on each side that attach the bumper to the fender---Take them out, then 2 more farther inboard---They will be obvious. Then there are about 4 screws holding the headlites in.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
SharX59
Sep 27, 2015 09:23 AM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
