Eliminating airbag light via resistor for curtain, would it work??
Old Sep 13, 2006 | 07:50 AM
wat_it_IS's Avatar
wat_it_IS
Question Eliminating airbag light via resistor for curtain, would it work??
I want to remove the airbag curtains and have been reading about the 2 ohms resistor for the seat airbags, would this be the same process to shut it off?
Anyone w/ ADVICE ONLY , I need your help, Thanks.
Old Sep 15, 2006 | 02:20 PM
wat_it_IS's Avatar
wat_it_IS
Cool
When and bought 2.2 ohms from Fried but havn't test it yet. We'll see wat going to happened.
Old Sep 16, 2006 | 12:07 PM
DIGItonium's Avatar
DIGItonium
I have never checked the impedence required by the sensor plug. The resistor tricks the sensor into thinking an airbag is there. A 2.2 ohm resistor is close enough.
I've done a similar trick with the Z32 when bypassing the det sensor as a test to get it out of safety boost.
Old Feb 10, 2026 | 02:48 PM
Shyananr's Avatar
Shyananr
have you ever figured out if it worked ? If so how’d you do it ?
0d5r3i5f0tZ
Oct 12, 2012 08:58 PM
jmicaelk
Nov 19, 2010 04:53 PM
Dr.TuB
Dec 14, 2009 01:07 PM
bigb996
Feb 24, 2009 09:16 AM
h0pes
Oct 15, 2008 03:00 AM
