Carbon Fyber Fenders?
Old Oct 29, 2006 | 05:03 PM
JCZ33's Avatar
JCZ33
Default Carbon Fyber Fenders?
I've seen hoods, hatch, and doors... how about fenders?
Old Oct 29, 2006 | 05:05 PM
cleanandquick06's Avatar
cleanandquick06
http://www.bodykits.com/nissan-350z-...1420_1421.html
Old Oct 29, 2006 | 05:06 PM
cleanandquick06
just one of many, erebuni makes most of them
Old Oct 29, 2006 | 07:06 PM
SixRB6's Avatar
SixRB6
www.seibon.com
Old Oct 30, 2006 | 04:58 AM
Jim@Showstoppers's Avatar
Jim@Showstoppers
I have Seibon carbon fiber and fiberglass 10mm fenders.
Old Oct 30, 2006 | 06:26 AM
sq40's Avatar
sq40
Not to Threadjack, But It looks like you can replace almost every body pannel with CF.. What would be the cost and weight savings by replacing every pannel / door / hatch / hood / bumper with the stuff that is available?
Old Oct 30, 2006 | 08:46 AM
Jim@Showstoppers
It all depends on the manufacture and what other parts you replace. For instance you save roughly 15lbs with just swapping the hatch, but if you switched to a lexan rear window at the same time your dropping 40+lbs. Hoods really wont save you much weight 3-7lbs but the vents help cool the engine. Doors depend on if you put all the stock parts back in the door but save over 50lbs and even more if used with lexan glass. So if you did go with everything carbon fiber you can drop atleast a couple hundred pounds, espeically if you went with lexan glass.
Old Oct 30, 2006 | 08:48 AM
sq40's Avatar
sq40
That would be an excellend way to increase performance. Looking at prices, (I know it depends on Manufactuer) it looks like about $4K for everything? (Not painted ofcourse)
How would one go about getting lexan all around?
Old Oct 30, 2006 | 08:54 AM
savvy's Avatar
savvy
all carbon fiber car would look sick
Old Oct 30, 2006 | 08:56 AM
sq40's Avatar
sq40
I Would have it painted, not much on the "Bling Factor", but It would look cool.
Old Oct 30, 2006 | 09:08 AM
Jim@Showstoppers
I have the lexan rear window precut and drilled for the Z in stock. The side windows you would have to get custom made I believe. If your serious about purchasing shoot me a PM with the parts you want and I can give you an accurate quote, it would be less then 4k thats for sure.
Old Oct 30, 2006 | 09:18 AM
sq40's Avatar
sq40
I have the lexan rear window precut and drilled for the Z in stock. The side windows you would have to get custom made I believe. If you serious about purchasing shoot me a PM with the parts you want and I can give you an accurate quote, it would be less then 4k thats for sure.
I'm "In between Z's" right now.. :0 But when I do get back in the game, You will be the first person I call for CF gear. (may be a couple of years though...)
Justin100
Nov 25, 2021 06:26 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
