help! fog lights
Old Nov 11, 2006 | 07:06 AM
lb's vq35's Avatar
lb's vq35
Question help! fog lights
has any one added any fog lights just needed to know how you did you wiring took a look last night but it seems that the only way to get the wire in the car was around the area were the battery is i was wondering if which there might be if theres a way to go through the the drivers side area...
Old Nov 11, 2006 | 08:27 AM
first350's Avatar
first350
there's a rubber grommet for electrical wiring to go through the driver's side of the bulkhead...it's in the brake compartment, under the all the components...on the interior side, it's near where the steering linkage goes through. (I ran my nitrous line through it...you'll have to slice it open to run the wiring, but you'd have to do that for the other side as well)
-Peter
Old Nov 11, 2006 | 08:33 AM
lb's vq35's Avatar
lb's vq35
i knew there was a place near the stearing but wasnt sure...so cut from the inside near the stearing...right im ganna see were its at tomarrow
-Peter
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
