Hid Question Please Help Me !!!!!!!!!
Old Nov 11, 2006 | 10:15 PM
TimeAttkZ's Avatar
TimeAttkZ
Default Hid Question Please Help Me !!!!!!!!!
I just finished the installation of my HID for my base model Z with the extreme lighting HID kit from chuck. I made sure everything was connected several times. The lights are not turning on though! There obviously not recieving power to the bulbs .....
this might sound stupid but when connecting the kit togeather which battery terminal are you connecting the kit to ?? POSITIVE OR NEGATIVE ?? I currently have it connected to the positive and like I said I have power issues .. i dont want to try the negative terminal unless im told this would fix my problem ??? HELP !!!
Old Nov 12, 2006 | 12:07 AM
andyman4lyfee's Avatar
andyman4lyfee
you hook the power or +12v to the +, and i believe the ballast needs to be grounded onto something... ground is the - sign. iunno if this helps? lol
Old Nov 12, 2006 | 12:22 AM
Current flows from positive to negative. Positive is the correct terminal.
As andyman4lyfee mentioned, you need someplace for the current to go - some sort of ground or return to the negative terminal. I don't know where that is.
A volt meter or continuity tester is a inexpensive tool. Begin at the connection to the battery and follow the lines. My assumption is that the lines are OK. You simply lack a proper ground.
Old Nov 12, 2006 | 12:43 AM
TimeAttkZ's Avatar
TimeAttkZ
PROBLEM SOLVED ... had nothing to do with the battery connections at all! Thanks anyways guys
Old Nov 12, 2006 | 12:58 AM
So what was the solution?
Old Nov 12, 2006 | 09:22 AM
djParis's Avatar
djParis
Retired Racer
probably the fuse
Pleask
Dec 21, 2021 03:17 PM
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
