Need Advice on TS hood.
SO got my hood today and it is damaged. YOu can see the dent and chip out of the CF dead center about 1.5-2 inches above where the latch is. My body shop signed for it so I may be getting stuck with the bill----last resort. If I do should I worry about stress fractures from opening and closing if I decide not to paint it. If i decide to paint it should I just leave the intakes CF and paint the rest to match my PPW??? Give me some good suggestions to brighten up my day!
Can you post a pic further away so I can see where it's at? I can't really tell by your description. If it's on the leading edge of the hood, it should be fine structurally; you'll want to use hood pins anyway. If you haven't mounted the hood yet, you may find you have trouble getting it to latch properly, anyway; I've seen some cut the latch loop off entirely and just use the hoodpins to secure the hood (get the locking kind if security is an issue).
As for painting and whatnot, if you want to keep the hood CF and that chip is just on the leading egde, you could just have that chip patched up with resin and then paint a very small black strip accross the front of the hood on the leading edge just thick enough to cover the chip. You'd hardly notice it, the damage would be covered and you'd still have a full CF hood showing.
I'd still try to talk to the seller and/or shipping company to see if you can get the issue resolved that way, though.
I am talking with the shipper and shipping co. Shipping co I am dissapointed in but the seller is a good guy and trying to help me out. The chip is right on where it bends under. I can't post a pick because it is too large but I could email you. Where and what kind of resin would I patch it with?
Check fitment without pins first. If you feel comfortable with it and its nots moving you should be fine without. However I always recommend pins with any aftermarket hood.
As for your shipping. The seller should have had insurance on the hood, if he did call the carrier (the sooner the better) and you will have to file the claim. For as big and fragile as these packages are you should always check them before signing for them and especially before installing them.
Good luck
Jim
Good luck
Jim
Good luck
Jim
Good luck
Jim
Originally Posted by MustGoFastR
You'd just patch it with a little fiberglass resin, then sand it smooth. After that, you can mask off a thin strip accross the very leading edge of the hood and spray it black with a can of spray paint. DIY will be much cheaper than having a shop do it for you.
Thanks for the advice, I may just do this, drive it for a while and if it gets worse or chips up, paint PPW to match.
I saw this pic a while back and that's where I got the idea! I like but I'm not sure I want to go that route. I already filed a claim about 15 mins. after delivery.
holy ... your car look sick can u post more pix?
Originally Posted by Jim@Showstoppers
You can still file a claim if it was signed for...but the longer you wait the slimmer your chances of them claiming the damage. You can always paint it like this
Sorry if the pic is too large; don't know how to scale pics.
Originally Posted by z350boy
Sorry to hear your misfortune. I have the same hood. I went back & forth about whether to paint or notr paint. IN the end I did paint it nad had the shop block off the vent so now the vents are carbon and the rest body color. Don't worry it will look nice. Here's a pic of my Z:
liqalu04
Jan 2, 2022 12:58 PM
user 62082028
Southern California
Jul 28, 2017 11:47 AM
