HELP!! my reverse lights do not work
Old Dec 31, 2006 | 10:21 AM
ESPO 774's Avatar
ESPO 774
Default HELP!! my reverse lights do not work
Ok, so a friend gave me LED bulbs for my reverse lights. i pulled the tail light to access the reverse bulb, put the LED in, and it did not work. Hmm, so i put the stock bulb back in, and nothingggg. Tried another stock bulb, and still nothingggg. what happened???
Old Dec 31, 2006 | 10:28 AM
Sean's Avatar
Sean
fuse?
Old Dec 31, 2006 | 10:31 AM
ESPO 774's Avatar
ESPO 774
is there a fuse for the reverse lights? location?
Old Dec 31, 2006 | 10:32 AM
ESPO 774's Avatar
ESPO 774
everything else still works. i dont understand. I only have 1 reverse light due to my euro fog, which replaced the drivers side reverse light. But everything else works, including the fog, both signals, etc.
Old Dec 31, 2006 | 11:30 AM
ESPO 774's Avatar
ESPO 774
Old Dec 31, 2006 | 11:34 AM
kPaNdA350's Avatar
kPaNdA350
Are you sure the bulb is plugged in correctly?
Both of the sides don't work? or just one side?
Old Dec 31, 2006 | 11:39 AM
ESPO 774's Avatar
ESPO 774
just the one side. i have a rear fog in place of one side similar to this car:
and the fog and such works fine
Old Dec 31, 2006 | 12:00 PM
rxkevin's Avatar
rxkevin
Check the fuses. There is one behind the battery, I know that one controls your brake lights, so I would assume it would also control the reverse lights as well.
Old Dec 31, 2006 | 01:13 PM
ESPO 774's Avatar
ESPO 774
theres a fuse box in front of the battery, but nothing there for the lights
Old Dec 31, 2006 | 02:10 PM
ESPO 774's Avatar
ESPO 774
checked every fuse under the dash as well. all good
Old Jan 1, 2007 | 11:44 AM
ESPO 774's Avatar
ESPO 774
ok now i plugged in an extra, fully functional, reverse/signal housing into the harness...and that one too doesnt work. so it has nothing to do with the bulb, or housing assembly. Can someone tell me what exact fuse the reverse light runs off of? maybe i overlooked it? any other assumptions???? help!!!!!!
Old Jan 1, 2007 | 01:54 PM
rxkevin's Avatar
rxkevin
There is a fuse box behind the battery. In order to even reach it, I had to remove the battery. The cover is a little tough to get off too.
Old Jan 1, 2007 | 03:13 PM
ksj's Avatar
ksj
This is the wiring diagram for the reverse lights. Hope it helps you find the problem...
Attached Thumbnails HELP!! my reverse lights do not work-backup.gif   HELP!! my reverse lights do not work-backup2.gif
Old Jan 1, 2007 | 03:16 PM
ESPO 774's Avatar
ESPO 774
found it. 10a fuse in the hidden fuse box along side the battery. thanks for all your help guys.
Old Jan 1, 2007 | 03:30 PM
Sean's Avatar
Sean
hoorah
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
