Anyone ever have a problem w/ bluebatmobile overlays?
Old Jan 1, 2007 | 11:00 PM
plumpzz's Avatar
plumpzz
Default Anyone ever have a problem w/ bluebatmobile overlays?
I ordered front amber tints, rear reverse light tints and a tail light tint. The amber and reverse light fit pretty close, but the tail light tint is WAY off?
Old Jan 2, 2007 | 01:58 AM
Kurru's Avatar
Kurru
the curve on the tail light was such a PIA for me. i got one on, looked decent not up to my standards. i tried putting other one on. was almost finished with 2nd and tore the tint. i decided it was to much frustration playing with tint for me. wasn't digging the way they looked in person much anyways.
i got the rear and front bumper lights on easy though.
Old Jan 2, 2007 | 04:23 AM
plumpzz's Avatar
plumpzz
thats retarded. what a waste of 40 bucks.
Old Jan 2, 2007 | 05:08 AM
jtabraham's Avatar
jtabraham
If you get them, don't make the same mistake I did of putting them on outside in cold weather. I used a hairdryer, but when it's 40 degrees out, the hairdryer is probably heating the air up to about 100 or 110 degrees max, which makes it incredibly difficult to form properly to the curves.
With ideal conditions, look to spend AT LEAST an hour or two to get the tail light overlays on. They are generally a little over-sized so that you can form them with room to spare and trim/tuck the excess. The reverse lights overlays should be a much tighter fit (read: less extra material)
Old Jan 2, 2007 | 05:24 AM
booger's Avatar
booger
I took my rear light overlays to a tint shop . They used a steam machine to heat them up and get it to lay down nicely
Old Jan 2, 2007 | 08:42 AM
Ghost 350z's Avatar
Ghost 350z
When you heat them up they stretch. Mine fit perfect when I stretched them a little
Old Jan 2, 2007 | 09:12 AM
sponsorsthisway's Avatar
sponsorsthisway
I've ordered overlays from Andy since back in the day when I had my Celica almost 5 years ago. Everything has always been top notch and fit perfect. Maybe some people need more experience applying them???
Old Jan 2, 2007 | 10:31 AM
plumpzz's Avatar
plumpzz
^maybe. Im going to try again today. It was pretty late last night and i only gave it 20 minutes of trying.
Old Jan 2, 2007 | 11:17 AM
sponsorsthisway
Yea man. A blow dryer and patience helps a lot. Take your time. Scrape out the air bubbles let it sit and adhere for a couple mins (hit it with the blow dryer a little bit then squeeze out remaining air/water. Once everything is good out to the edges use the blow dryer to soften up the overlay making it more flexible, use your fingers to for the overlay around any overlaping edges. Use the blow dryer to make them stay where they are. Take your time, be patient and mess around with it.
Old Jan 2, 2007 | 11:22 AM
jtabraham's Avatar
jtabraham
I actually found the overlays a lot more forgiving than i thought...but like I said before, don't put them on outside in cold weather.
Old Jan 6, 2007 | 03:21 PM
youngZ33's Avatar
youngZ33
hmmm im having trouble with "less material" then more...
put my thumb to see how much material was missing on my signals. was about half a thumb. anyone here also?
Old Jan 6, 2007 | 04:41 PM
Fluid1's Avatar
Fluid1
I tried both the headlight and taillight two different times each, could never get it to fit right. It's really a crappy material to work with especially in relation to tint. It's also a total b!tch to remove. I wouldn't recommend the product to anyone.
Old Jan 6, 2007 | 04:52 PM
z-u-later's Avatar
z-u-later
Took mine to the tint shop. Let professionals install it for you.
Old Jan 7, 2007 | 12:35 PM
MarlboroMan's Avatar
MarlboroMan
It takes a lot of patience. It took me about an hour per tail light. Make sure to keep the part your working with wet. Once you get it right, then use the hairdryer like sponsorsthisway said.
Wet it -> heat it -> stretch it -> dry it. just take your time.
Old Jan 7, 2007 | 11:51 PM
PHARM Z's Avatar
PHARM Z
I have the tails, the rear blinkers and sidemarker overlays. As everyone has stated the tails are a PITA but the others are easy. Just make sure to have a friend help you. I've had them on for 2 years and I get nothing but compliments and NO PEELING.
robbinsj
Dec 25, 2008 03:16 PM
jdohman
Apr 14, 2008 11:47 AM
Bday350z
Oct 29, 2006 06:24 PM
DevinB
Mar 24, 2006 09:27 PM
Blue Batmobile
Jun 5, 2004 03:17 PM
