Engine plastic paint???
Does anyone know of or have used a good brand to paint the engine plastics under the hood of my Z...something that can take the heat and look good..please help!!!!!!!!!!111
Im pretty sure they make a engine grade paint, just go to Kragen or Pep boys. The paint can withstand super high temps. You have have to sand the cover before you paint though... ?
The plastic doesn't get hot enough to require high temp engine paint. First, plastic pieces need to be sanded and primed with Bulldog Primer - that sticks to plastic so the paint will stick to it.
I ordered a can of spray paint from TowerPaint.com - all you do it give them your factory paint code and they'll send you a can of spray enamel or acyrlic that matches perfectly.
Finally, hit it with a few coats of clear-coat and it will be done.
Originally Posted by 350Zbest
Does anyone know what would be the best way to remove and put back the emblem on the engine cover if I were going to paint it myself?
Thanks for any help.
I believe there are two plastic rivets on the back side. You just drill the head off those and use a flat head screwdriver to pry it up.
Originally Posted by Eazzzzzzy
No rivets,no drilling, just 2 alignment studs, use a heat gun/hair drier carefully on it and just pry it off
I must have been thinking about the strut bar then. Oops.
note: don't be a doofus and heat the fork as well.
