Looking for best hood struts with a CF Hood
Old Jan 15, 2007 | 01:08 PM
TayTaythatsme04's Avatar
TayTaythatsme04
Default Looking for best hood struts with a CF Hood
Hey Guys,
well the stock hood stick (whatever) is starting to wrap my hood and I need some hood struts that will work with a CF hood, so that my hood doesnt fall to one side when the hood is up.
experiences and where I can find the product
and would like little to no modification
Thanks
T
Old Jan 15, 2007 | 01:27 PM
Endless Shock's Avatar
Endless Shock
A while back I remember seeing some teins... I dont remember how much modding is required to fit these on (since I dont have them personally). Hope that helps...
Old Jan 15, 2007 | 01:29 PM
TayTaythatsme04
Looked into those they are to strong for CF
T
Old Jan 15, 2007 | 02:06 PM
nofeardude87's Avatar
nofeardude87
http://cgi.ebay.com/ebaymotors/NRG-3...70391755QQrdZ1
Old Jan 15, 2007 | 02:15 PM
JasonZ-YA's Avatar
JasonZ-YA
Mine are not to strong....you lift the hood up completely after poping the latch and about a little over halfway up then it takes over from their gently - i honestly believe it will work for CF hoods no problem! the gas strut is only a 45 lb one so its not to strong and you can order a weaker one if you want.
its a fun DIY project!
https://my350z.com/forum/body-interior-exterior-and-lighting-diy/229425-diy-hood-damper-hood-prop.html
let me know if you have any questions....
- j
Old Jan 15, 2007 | 03:36 PM
TayTaythatsme04
https://my350z.com/forum/showthread.php?t=229425
- j
thats some nice work, but I have to many DIY projects already. Anybody know of some strait out of the box set I can use ?
T
Old Jan 15, 2007 | 04:16 PM
SpoilsofWar's Avatar
SpoilsofWar
I would think any struts that work on the stock hood will work on a CF one... There is almost no difference in weight.
Old Jan 15, 2007 | 04:23 PM
TayTaythatsme04
true in that they both weight close to the same amount but the CF hood will flex much more then the stock hood will. so if your struts are to strong they will crack your hood
T
Old Jan 15, 2007 | 04:26 PM
Mike Wazowski's Avatar
Mike Wazowski
I have tested 3 diff set of hood struts and wouldnt use any of them with a CF hood.
Old Jan 15, 2007 | 04:54 PM
SpoilsofWar
good point. Hmm, I have a CF hood too and hate the way the one side sags when its on the hood prop.
Old Jan 15, 2007 | 05:05 PM
Mike Wazowski
maybe install a second hood prop? just a thought.
Old Jan 15, 2007 | 09:31 PM
TayTaythatsme04
to much of a hassle, there has to be a low force strut that is just enough to push the hood up but not do any damage to the hood it-self
T
Old Jan 15, 2007 | 09:35 PM
Mike Wazowski
T
I dont think the pushing it up is what you need to worry about with the CF. It is the closing that is going to get you. Even with a lower pressure shock it is going to add stress to the CF eventually cracking either the clear coat or the CF itself.
Old Jan 15, 2007 | 10:20 PM
TayTaythatsme04
Ya, thats what I was talking about its the force when its in the process of being closed and closed all together, thats Im worried about. But the thing is that the hood is starting to bend off to the right because of the hood stick only holding up one side
T
Old Jan 15, 2007 | 10:35 PM
r0mey's Avatar
r0mey
wont the teins work well?
Old Jan 15, 2007 | 11:49 PM
TayTaythatsme04
to strong for the CF
T
Old Jan 16, 2007 | 06:37 AM
THE TECH's Avatar
THE TECH
The Teins have nothing to do with stressing the hood. They are mounted to the bracket for the hood. I don't see any way they could stress the hood.
Old Jan 16, 2007 | 07:34 AM
PumpedVA's Avatar
PumpedVA
I have teins now with OEM hood and waiting on my FG hood to be painted. what I am planing is to drill out the teins to release the pressure and use a small pin though the hole to hold the hood up. I cant see buying new ones and I have color matched mine so didnt want to repaint. I have done this with the rear hatch and works fine. Just dont loose those pins.
Old Jan 16, 2007 | 07:45 AM
THE TECH's Avatar
THE TECH
^Seems like more work than using the stock hood prop.
Old Jan 18, 2007 | 04:30 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
T
no such product exists....every damper will need modding or removal of the plastic shrouds in order to fit due to engine bay design
with a carbon hood, your best bet is no damper at all unless you have a real carbon hood (not a typical seibon type fiberglass/carbon). The reason the stock prop makes most hoods bend is that most aftermarket carbon hoods are heavier than stock. The ones lighter than stock won't do this (mine doesnt as it weighs about 1/2 of what the stock hood does), though the flipside is they are about 2 -3 x the cost
