DIY gone Bad!!
Old Jan 16, 2007 | 07:41 AM
cturnbull802's Avatar
cturnbull802
Default DIY gone Bad!!
so the idea was to polish my uper intake in the downtime i have at work, it started out ok. i used a air powered wheel to remove all the casting marks.
this went ok, but now i have a bunch of indents where the wheel dug in any tips on removing these since trying to sand them out by hand is taking hours, and i am ready to just paint this thing.
on with the pics
Attached Thumbnails DIY gone Bad!!-dsc03771.jpg   DIY gone Bad!!-dsc03772.jpg   DIY gone Bad!!-dsc03773.jpg   DIY gone Bad!!-dsc03774.jpg
Old Jan 16, 2007 | 07:43 AM
rAiN's Avatar
rAiN
sell that thing and get the one that is already painted.
Old Jan 16, 2007 | 07:55 AM
JasonZ-YA's Avatar
JasonZ-YA
sounds like too much RPM's and too rough of a pad...
get a softer pad attached to like a dremel...something that you can set the rpms and there is no way of going over...try a 18 volt drill maybe too.
take your time...
- j
Old Jan 16, 2007 | 08:01 AM
DROPPEDIT2WCE's Avatar
DROPPEDIT2WCE
Black and decker mouse sander for larger flat spots....
Old Jan 16, 2007 | 09:31 AM
davidf's Avatar
davidf
DA sander.
Old Jan 16, 2007 | 09:32 AM
davidf's Avatar
davidf
Another name for it is orbital sander.
Old Jan 16, 2007 | 09:34 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
you are fine, sent you a pm
Old Jan 16, 2007 | 09:41 AM
ARMSTRONGARMS
I will buy it
Old Jan 16, 2007 | 09:42 AM
ARMSTRONGARMS
take your time...
- j
A dremel is a waste of time, these are way to big(plenum). you need the right tools for the job
Old Jan 16, 2007 | 10:32 AM
first350's Avatar
first350
if you're going to paint it, get some bondo or JB weld and fill in the bad areas...go over it by hand and make it all smooth, then paint.
...I did mine like that and am currently painting it. (I removed the 5 long humps, and 6 bolts in the middle)
this is my first paint job...w/out the humps and bolts holes removed:
Old Jan 16, 2007 | 09:00 PM
kukles's Avatar
kukles
Just make sure you get some high temp clear-coat for it when you're done...I think its on Joe's car that the finish is gone from a heavy-duty engine cleaner, and its got stains all over it and generally looks like chit...
BTW, if you didnt hear, I'm keeping the car for sure now..
Old Jan 18, 2007 | 10:22 PM
cturnbull802
i put some time in tonight and its looking better
Attached Thumbnails DIY gone Bad!!-dsc03818.jpg   DIY gone Bad!!-dsc03819.jpg   DIY gone Bad!!-dsc03820.jpg   DIY gone Bad!!-dsc03821.jpg
Old Jan 18, 2007 | 10:31 PM
ARMSTRONGARMS
People dont realize how much time this takes, now you know buffing it out is just as fun.
Old Jan 18, 2007 | 10:41 PM
cturnbull802
when i am done it probably wont be perfect, but at least i learned something from all this
Old Jan 18, 2007 | 11:48 PM
ARMSTRONGARMS
which is??? it's a real pain to do this??
Old Jan 18, 2007 | 11:59 PM
Cannysage's Avatar
Cannysage
you won't know pain until you've felt the wrath of stuck pulley bold or the Cats bolt
Old Jan 19, 2007 | 07:36 AM
cturnbull802
i did on my old car. had to drill out all 3 studs on the cat. that sucked.
Old Jan 19, 2007 | 06:06 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Or break the bolt that rear strut pillow mount mounts to.. My buddy had to drill a big enough hole on the rear strut bar and hammer out the broken bolt... S@$tty deal... Thankfully the bolt was pressed on, not welded on...
Back to the topic....
Polishing takes too much time.. Just chrome the damn thing~
Old Jan 19, 2007 | 07:16 PM
first350's Avatar
first350
looking good! I think the polishing part is the hardest...it's so hard to make everything look clean - good luck and thanks for the pics!
-Peter
Old Jan 19, 2007 | 07:21 PM
cturnbull802
i have to come in to work tomorrow to run production on 2 machines, so i plan to get some time in the shop
