takata harnesses
Old Jun 25, 2008 | 03:20 AM
chris'smax's Avatar
chris'smax
Originally Posted by SpoilsofWar
Not arguing that its better then nothing, but the Cusco cage is basically a show piece. I know none of the tracks around me will accept a bolt in chromoly cage, its either DOM or go slow.
If you are serious enough to need a cage, then you should know that you need welded DOM. If its just for a show car or a place to mount harnesses on a street car (why you'd need harnesses on a street car I dont know, but regardless) then the cusco will suffice.
yea i didn't know that NONE of the racing organizations would accept a bolted in cage. At first i thought it was just a couple of the more serious racing organizations. Anyhow in order to remedy it i am going to have it welded (should be fairly easy).
Old Jun 25, 2008 | 05:13 AM
Moroccan_Mole's Avatar
Moroccan_Mole
this is correct - the cusco cage isn't legal to run with any of the major racing orgaziations.
I thought it had an optional harness bar piece?
If it doesn't, aside from putting it in a show car, I can't see any purpose for it at all.
there is an optional bar for the cusco cage; however, it's not good for anything ... well you could possibly mount a camera on it, but that's about it.
Old Jun 25, 2008 | 03:55 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
its legal in D1 - at least it was last time I checked (might have since changed)
the optional bars as mentioned are not designed to be harness bars
Old Jun 25, 2008 | 04:02 PM
Ruthless18x's Avatar
Ruthless18x
+1 the cage is D1 legal, and I believe there are a few people who have welded them (240s, Civics) to make them NHRA legal? Correct me if I'm wrong.
I also have the rear carbon bar and it's definitely not for harnesses.
I purchased a set of short Takatas and plan on running the Sparco bar underneath, might have to fab a little but should fit fine. The cage really ****ed up my seatbelts and they no longer retract without the bar getting in the way.
Old Jun 26, 2008 | 11:11 AM
Moroccan_Mole
i was thinking of like nasa, scca, pca, pboc, etc...
you might get away with it if you weld it for some of the racing orgs, i know that the bars are not thick enough for nasa.
Old Jun 26, 2008 | 11:23 AM
chris'smax's Avatar
chris'smax
wooohhooo well i am going to enter D1 then
Old Jun 26, 2008 | 11:29 AM
Crom's Avatar
Crom
Good info....
m_0g
Jun 3, 2021 10:05 AM
HoBrahYouStink
Jun 24, 2016 10:58 PM
speedsniper
Sep 14, 2015 08:46 AM
BlinkerFluid
Sep 8, 2015 10:06 AM
