Fuse panel question
Old Feb 5, 2007 | 03:59 PM
sumfknguy's Avatar
sumfknguy
Default Fuse panel question
When looking at the fuse panel under the driver side kick plate:
All of those extra unused fuse slots.. are those hot? Can I tap into this with a fuse and utilize it?
Also, i have seen where some hard wire kits for misc items come with a mini-fuse with a wire attached to it.. does anyone know where I can get these?
I am about to venture into some projects and would like to keep everything as clean as possible..
Old Feb 5, 2007 | 04:20 PM
gNaRKiLL's Avatar
gNaRKiLL
only way to know for sure is to get a voltmeter out and start testing. I would assume they are not hot and are probably for the various options that come on the other Z's.
Old Feb 5, 2007 | 04:28 PM
JasonZ-YA's Avatar
JasonZ-YA
look at the panel door, it has a label schematic on it. there are two that i use! they say ACC. i believe one is the cigaratte lighter and the other i forgot. but they have ACC on them.
which means they turn on when the car is ON or at least on ACC. if you dont know what i mean look at your key hole on the stearing colum.
but ya, a voltmeter would be great.
as for those add an accessory mini fuse adapters your talking about - AutoZone has them. im sure most general autoparts store will have something similar.
let me know if you have any questions.
- jason.
Old Feb 5, 2007 | 04:38 PM
sumfknguy's Avatar
sumfknguy
- jason.
grassy ***!! *runs to Autozone*
kyin
Oct 15, 2015 05:54 AM
Mattg350z
Oct 2, 2015 06:51 AM
