how to install ings lip?
Old Feb 27, 2007 | 04:47 PM
JonnyRod's Avatar
JonnyRod
Default how to install ings lip?
my ings kit just came in and i was wondering what the best way is to install the front lip. just the 3M double sided tape? if someone could help me out it would be greatly appreciated
heres the front and sides im talking about (polyurethane):
Old Feb 27, 2007 | 05:10 PM
brandonanix's Avatar
brandonanix
no way, dont just use the 3m tape, I did that and it fell off while I was driving! luckily it was a test run and i had not yet painted it. 3m tape it on, then put a few screws in each side of the wheel opening
Old Feb 27, 2007 | 05:21 PM
JonnyRod's Avatar
JonnyRod
alright thanks...is there anything underneath to attach to?
Old Feb 27, 2007 | 05:31 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
you are best off glueing it to your bumper
that being said. Pay someone else to do a good job haha
Old Feb 27, 2007 | 05:52 PM
JonnyRod's Avatar
JonnyRod
yea thanks for the advice but i can put a lip on a bumper. i just figured i could get some ACTUAL advice from someone who has had this lip before. ya know? a tip or trick thats all
Old Feb 27, 2007 | 06:12 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Actually, I own this kit. If you use the search function you will find that many people who have installed this kit have ended up molding the lip onto their front bumper.
When I first got the kit I thought I could just paint it and slap it on. No good. After you work with the 3m tape a little bit you will find that it sticks about as well as scotch tape if it gets just a little bit dirty.
Do you have an authentic kit or a replica?
Old Feb 27, 2007 | 06:48 PM
Riyazsf's Avatar
Riyazsf
Where do u buy good 3m double sided tape from?
Old Feb 27, 2007 | 06:50 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
any autoparts store, get the 3m trim/molding tape. It has the red sheilding that you pull off.
Old Feb 27, 2007 | 06:53 PM
first350's Avatar
first350
home depot also has it in the paint section.
Old Feb 27, 2007 | 07:47 PM
Track's Avatar
Track
The more I see this lip the more I like it. I just don't like the sides. Would it look okay with the lip only if it was molded?
Old Feb 27, 2007 | 08:15 PM
StraySheep's Avatar
StraySheep
From the instructions in the authenic ings+1 front lip, there are 2 screws on each side of the lip that goes through the lip into the front bumper at the fender area near the bottom.
Then the middle section underneath the grill is all 3M double sided tape.
Other's that have this lip installed will find that the 3M tape doesn't hold well because after a few scrapes and some dirt, the tape doesn't really hold the lip that well. Then you will start that see the middle section sag a bit, I'd say about a quarter of an inch.
As in my case, the 3M tape in the middle doesn't really stick any more and the lip is really just held on by the 4 screws. But since mine is authentic, it fits pretty tight, so there isn't much gap between the lip and front bumper.
Old Feb 27, 2007 | 08:41 PM
brandonanix
I gave up on the 3M tape after about 3 re-tapings. I was told to try 3M velcro, and it worked like a charm! I would do the velcro in the center section under the "mouth" and just screw the sides in.
Old Feb 27, 2007 | 10:05 PM
Riyazsf's Avatar
Riyazsf
can u get the velcro from the same places? home depot...?
Depravity
Oct 1, 2015 04:49 PM
