InStant Fill replacement gas cap. Bad idea?
Old Mar 22, 2007 | 09:29 AM
zeeanswer's Avatar
zeeanswer
Lightbulb InStant Fill replacement gas cap. Bad idea?
I am thinking about getting this for the Z. I hate removing the gas cap and letting it hang there and scratch my paint. This seems like this would work great.
Refueling is now quicker and cleaner than ever.
Removing a gas cap can be a difficult, dirty task. And replacing one after you forget about it and drive away can be expensive. The InStant Fill's trap door mechanism accommodates the gas nozzle, eliminating the hassle of removing and replacing the cap each time you refuel. With the InStant Fill fuel cap, just insert the nozzle fully and squeeze the trigger. You’ll never touch a fuel cap again! Four different models fit over 80% of the cars on the road in North America and InStant Fill meets onboard diagnostic (OBD) emission specifications, so it will not trigger the "check engine" light on late model vehicles. Not recommended for use in areas where vapor recovery nozzles are used.
http://www.autosportcatalog.com/inde...=4044&addcar=1
Does anyone have this already? Does anyone think it would be a terrible idea?
Thanks,
ZeeAnswer
Old Mar 22, 2007 | 09:33 AM
halfass872's Avatar
halfass872
I think it's a neat idea. But honestly unless you are trying to make a pit stop out of your fill up, i'd leave it how it is. I know our cars rely on a certain amount of pressure in the tank. And i think if that cap leaks even a little it will cause issues with the venting etc. of the gas tank. SO probably more trouble then it's worth. My 2 cents.
Old Mar 22, 2007 | 09:42 AM
zeeanswer's Avatar
zeeanswer
I see your point. I am interested in it completely for the paint saving. Both my Sentra and my Frontier had a plastic holder that the gas cap would clip into on the inside of the fuel door. This was so much nicer than the tether system the Z has. I hate the thought of the gas cap sliding along my paint, especially when the car is dirty.
I could just cut the tether off and set the cap on the pump, but I though InStant Fill cap would be easier and eliminate the risk of forgetting the cap. For $15, I am thinking about pulling the trigger and giving it a shot.
Old Mar 22, 2007 | 09:48 AM
cubu's Avatar
cubu
your fuel door doesn't have a hook for the gas cap? mine does... there is a ring of sorts where the strap connects to the gas cap that i put onto the hook on the gas door
Old Mar 22, 2007 | 09:51 AM
JPsZ's Avatar
JPsZ
mine too
Old Mar 22, 2007 | 10:08 AM
RedBullRR's Avatar
RedBullRR
My car has the ring thing to to hang it up. Although it can be a PITA to hook it on. I kind of like this lil gadget. Let me know how it turns out.
Old Mar 22, 2007 | 10:09 AM
THE TECH's Avatar
THE TECH
Same here. Give it a try though and let us know. Can't be more than 20 bucks.
Old Mar 22, 2007 | 10:33 AM
realcom2's Avatar
realcom2
i would not trust that it will prevent the check engine light to come on. I had to use a replacement cap for a few days once and that still caused my light to come on.
Old Mar 22, 2007 | 10:37 AM
fanboy's Avatar
fanboy
If you don't like you gas cap to hang down then just take off the plastic strap that holds it on. If your in a state where they pump your gas for you(im in NJ i don't have to any of it) then the guy will put your cap on top of the pump instead of just letting it lay there
Old Mar 22, 2007 | 10:44 AM
zeeanswer's Avatar
zeeanswer
I have considered the tether delete. However, this seems like it would be way more convenient.
Full service gas stations are a thing of the past (for the most part) here in Michigan.
Old Mar 22, 2007 | 10:46 AM
zeeanswer's Avatar
zeeanswer
I have heard that AutoZone will turn off the light for you for free. The dealer tried to charge me $70 once to turn it off when I had my Sentra. I complained and he eventually did it for free.
Old Mar 22, 2007 | 10:48 AM
fanboy's Avatar
fanboy
It also says do not use with Vapor recovery nozzles. Which almost all gas pumps have.
Old Mar 22, 2007 | 10:50 AM
zeeanswer's Avatar
zeeanswer
I have never heard of this before. Is this something that is vissibly different about the pump??
Old Mar 22, 2007 | 11:26 AM
cellude's Avatar
cellude
Those are the ones with the accordian boot around the nozzle.
Old Mar 22, 2007 | 12:20 PM
s3fddiZ's Avatar
s3fddiZ
Not in Oregon. They get pissed at you if you try and fillup your own gas.
Old Mar 22, 2007 | 12:51 PM
Cheezwiz's Avatar
Cheezwiz
Not recommended for use with vapor recovery nozzles... your gas station probably has these.
Old Mar 22, 2007 | 01:26 PM
zeeanswer's Avatar
zeeanswer
Michigan gas stations are not required to have these type of nozzles. Apprently environmentalists are pissed about it too. Seems like Michigan is one of the last states to mandate the use of vapor recovery systems. WTG Michigan
Old Mar 22, 2007 | 06:24 PM
Fletch69z's Avatar
Fletch69z
Most IN pumps don't have gas recovery sleeves. Are you an environmentalist or something Zeeanswer? Why are you driving a Z instead of a Civic Hybrid?
liqalu04
Jan 2, 2022 12:58 PM
07ZEKE
Aug 23, 2021 09:15 PM
kyin
Oct 15, 2015 05:54 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
