Swapping trim Parts. Need help!
Old Apr 28, 2007 | 12:04 PM
AdriaN-'s Avatar
AdriaN-
Default Swapping trim Parts. Need help!
Well here is the situation, I just got word that my buddy has in his shop a Totaled 03 Touring 350z It has the burnt orange leather seats and all that other stuff the touring featured. I have an 06 base and I wanted to know if it is possible or if it has been done to swap the regular base model seats for the leather power'd seats? Oh and I was also intrested in the LSD and BOSE radio... Would I be able to take it off from the 03 and put it into my 06? Any suggestions or answers would be of much help =)
Oh and if there is anything else i should but from it, let me know :P
Old Apr 28, 2007 | 12:11 PM
VicPham's Avatar
VicPham
Lifetime Member
Everything should swap over just fine.
Old Apr 28, 2007 | 12:14 PM
AdriaN-'s Avatar
AdriaN-
but my main questions is the seats... They are power opposed to my manual seats. How would the switch work?
Old Apr 28, 2007 | 12:20 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
you need to tap into the power obviously..i heard 06 had different rails than previous models..maybe im wrong
VicPham's Avatar
VicPham
Lifetime Member
Even though your car is a base model, it should have some sort of wiring already hooked up. It should be plug and play. If not just take the wiring out of the 03 Touring.
My cuz had his car repossesed but before they took it he swapped everything into his friends base model Z. Even the power seats too. And they still work. The only they didnt swap over was the VDC/TCS.
Old Apr 28, 2007 | 01:20 PM
AdriaN-'s Avatar
AdriaN-
intresting
Old Apr 28, 2007 | 01:27 PM
Lsmith9523's Avatar
Lsmith9523
AdriaN-,,,,,,I can tell you swapping non-bose to bose is almost impossible. The bose set up is powered by its own amp and own ohm speaker set up. You would have to change out all the stereo wiring, install the bose amp, swap out all non bose speakers to the bose speakers. Check out the audio/video forum on this site. Do a search,,,,you will see/read what a pain that swap would be. Plus, the Bose has so many problems,,,,you would be better off keeping your stock or if you wanted something different,,,,go Aftermarket audio set up.
I hope this helps,,,,,,The Burnt Orange seats sound HOT!!!!! Post pics when you get them installed.
Old Apr 28, 2007 | 01:48 PM
AdriaN-'s Avatar
AdriaN-
Thanks for the headsup lsmith9523. Im going to try to get the seats and LSD shortly... I can only hope =)
BEBO'S ZEE
Jun 7, 2016 07:48 AM
SpartanZ32
Oct 22, 2015 09:36 AM
Tochigi_236
Sep 27, 2015 03:40 PM
SharX59
Sep 27, 2015 09:23 AM
