ING´S LX how to jack up car???
Old May 1, 2007 | 12:35 AM
XM 1's Avatar
Default ING´S LX how to jack up car???
i finally installed my ING´S LX bodykit (sides not) and i was just wondering how to jack up the car after the sides are on???? could i still use the nissan floor jack? or are there other possibilties?
Old May 1, 2007 | 12:42 AM
lilphill619's Avatar
lilphill619
Im kinda curious about the answer to this question as well. After my lx side skirts were put on I couldnt even see the jack points? Anybody?
Old May 1, 2007 | 12:44 AM
imalazeeass's Avatar
imalazeeass
for my g35 coupe w/ low sideskirts i use takata ramps then a low profile jack.. stock jack does not work for me regardless... hope that helps. You can also try going over some 2x4's but your best bet is to find those low profile takata ramps..
Old May 1, 2007 | 02:13 AM
XM 1's Avatar
hm thx.....that was exactly what i was thinkin´about
that´s why i put first my rims on and after that i´ll pu the sides on
Old May 1, 2007 | 04:47 AM
MUZZY's Avatar
MUZZY
if u look at the old jack point and project about 8" in to the car you will see another rail type support that runs down the car. it is flat. and that is a suitable jack point. it is made for jack stands really. but I do not recomend using the factory jack for this location since it can not lock into place and may slip.
Old May 1, 2007 | 08:41 AM
XM 1's Avatar
^^ i´ll keep that in mind
damn my amuse exhaust comes in next week and i have no clou how to fix the jack prob asap :-P
Old May 1, 2007 | 07:25 PM
Checkmate58's Avatar
Checkmate58
If you're going to install your exhaust, you could have some ramps and just back up onto them backwards. Just make sure someone is there helping you on where to stop to car before it flies off the ramp.
You could also use a few 2x4's and move the car up on fronts forwards too. Then you can just use the jackpoints.
--Sam
Old May 1, 2007 | 07:27 PM
05-Z's Avatar
05-Z
I use velcro.
J/K....I take them before doing anything. 7 minutes a side.
Old May 1, 2007 | 07:37 PM
taurran's Avatar
taurran
Stair step boards. I had an accident the other week while doing this and my front lip has some issues now. If you can get some low-pro ramps it will help.
Old May 1, 2007 | 08:16 PM
synth19's Avatar
synth19
A few friends and I installed my D-Spec shocks a few weeks ago. Let me tell you this, it literally took us longer to raise the car then to install the shocks. Originally I was thinking of starting with the stock jack and then once I got it up a bit, moving to a conventional... but guess what, no clearance! Keep in mind I have the central 20 sides, but they look very similar and are about the same size as the ings. The BEST way to raise the car is to go from the rear, from the pumpkin. Then, once you get it high enough, get another jack and raise one side, insert jack stands, then do the other side.
Old May 2, 2007 | 08:59 AM
XM 1's Avatar
thx for replies....i was also thinking about your solution synth19
i think i´ll have not probs with the rear but i´m not quiet sure about the front...but i still have 6 months to find a good solution for that
@taurran: wow sad to hear that, cause your car inspired me to do the same to mine always loved the way your car looks like ( even although i had to buy a new us oem rear bumper-->600$ unpainted!!! wtf :-P )
btw here is a quick pic of the my Z and what it look right now (not washed and just a quick shot)
i´ll wash her at the weekend and take some better pics then
Old May 2, 2007 | 10:56 AM
bbs350z's Avatar
bbs350z
omg ur volks!!!
Old May 2, 2007 | 06:56 PM
micmicmotorbike's Avatar
micmicmotorbike
fronts i use takata low down ramps. and rear i jack up using the differential. this is wen i use my friends lift. front lift points are subframe next to where the cats sits...and rear points i use the jack mount points with 4x4s cut into blocks.
hope this helps.
at first it used to take longer to get the car on the lift than to do a whole oil change.
haha.
sucks...life of a modder.
etkms
Jun 19, 2022 06:30 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
Mattg350z
Oct 2, 2015 06:51 AM
