So...twisting off the stock knob (clarification)
Old Jun 20, 2007 | 01:56 PM
TenTilFour's Avatar
TenTilFour
Default So...twisting off the stock **** (clarification)
So I'm about to install a nismo leather ****, and I was forum searching all the posts about installing a new shift ****.
What can I do to prevent from twisting the linkage? Some posts say you need to avoid it, and others say just have at it with vice grips...Any suggestions? This is a stock **** so I'm guessing the glue will still be on it.
Old Jun 20, 2007 | 02:15 PM
usmanasif's Avatar
usmanasif
In another thread last month, I had posted a screen shot of the Nissan FSM page that addresses this topic. Search and you should find it.
Old Jun 20, 2007 | 03:16 PM
TenTilFour's Avatar
TenTilFour
Okay I found your post and popped off the little center console thing, and I just put one of my vice grips on the rubber part underneath the cotton? It doesn't seem like it would grip that well and I couldn't pull back the rubber very well to grab metal.
Old Jun 20, 2007 | 03:20 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
Search and you shall find...
https://my350z.com/forum/body-interior-exterior-and-lighting-diy/207539-diy-install-shift-knob.html
Old Jun 20, 2007 | 05:32 PM
MustGoFastR's Avatar
MustGoFastR
Yes, grip it tight on the rubber; it'll grip the shaft quite well with the help of the rubber. Then hold the vice grips stationary and twist like a ****. My tranny had been previously replaced, so the **** had been off before, but it was still a b!tch to unscrew.
Old Jun 20, 2007 | 05:43 PM
bb1314's Avatar
bb1314
da Terminator!
Changed mine last weekend. Yea, just pop off the cover, grip the rubber, then twist the OEM **** with whatever took you have. It's actually pretty easy.
Old Jun 20, 2007 | 06:22 PM
TenTilFour's Avatar
TenTilFour
okay awesome, I will do this.
Old Jun 20, 2007 | 06:24 PM
SuperBlack350z's Avatar
SuperBlack350z
watch out, this is what happened to me. And i did it the proper way and the way others told me to do.
https://my350z.com/forum/exterior-and-interior/280766-how-do-you-like-my-new-shift-knob-pics.html
Old Jun 21, 2007 | 09:30 AM
TenTilFour's Avatar
TenTilFour
my stock **** is pretty much trashed, the leather is completely worn off by the shift pattern...It can be destroyed
Old Jun 21, 2007 | 11:42 AM
Blazemaster's Avatar
Blazemaster
I don't know maybe my 04's previous owner had already removed the **** once. When I put on the leather nismo shift ****, all I had to do was hold the the shifter still with one hand on the shift boot and turn the **** counter clockwise and it came right off. After I installed it, I took it out for a drive to get a feel of it. For some reason, I'm getting a bit more grinding on second gear than before, should I be worried that maybe I did something wrong? I wouldn't say it's grinding all the time, just a bit hard to push it into 1st and 2nd gear.
Old Jun 21, 2007 | 12:36 PM
TenTilFour's Avatar
TenTilFour
Twisted it off today, it wasn't that bad. The worst part is just the stress of worrying about the linkage rod twisting... I had one hand on the vice grip and twisted the **** with the strap wrench... My ****'s finish was unharmed from the strap wrench, it was a very effective method at preserving your old shifter. (Mine was an 03 and I had to get past the locktite)
Old Jun 21, 2007 | 12:37 PM
TenTilFour's Avatar
TenTilFour
hmmm not sure there, as long as it's not grinding or really awkward feeling I bet it's more of a psychology thing... I kinda had the same feeling when i was driving but the shift pattern runs like better stopped so..
Old Jun 21, 2007 | 04:35 PM
Blazemaster
I drove a bit more afterwards and I actually didn't notice any grinding at all, guess I just didn't stepped the clutch down enough before(thank god). I like the Nismo leather shift ****, it's shorter than the OEM, so kinda feels like you got a short shifter mod.
sherm
Apr 11, 2020 05:21 PM
