Brake Light
Old Jun 20, 2007 | 09:58 PM
BlackZ05's Avatar
BlackZ05
Default Brake Light
Before you think that this is just another post about my brake light coming on cause i'm braking its not. Actually its the other way around, I do know the following A. My clutch is going i have a replacement just havent had time to put it in yet an B. my brakes do need to be replaced. But anyway when i'm driving around an i start to get on it mostly 1st threw 3rd now an then the brake light will come on an stay on till i start driving normal again. Tonight i got on it leaving a light didnt lose any traction till 2nd gear shift an it came on instantly an stayed on till i shifted into 4th an even then it took about 30seconds or so to go out. Any chance anyone knows if this is telling me HEY your clutch just slipped a **** load an it stills slipping cause i mean it as soon i slowed down i did notice that the clutch deffintly cooked some. I plan on replacing the brakes an clutch soon my self an i'm kinda hoping this isnt a problem were it has to go back to nissan.Any info would be helpfull.
Old Jun 20, 2007 | 10:12 PM
ctwentytwo's Avatar
ctwentytwo
Give me a break. Give me a brake. Break me a piece of that ***. Put the brakes on that ***. Are you going to fix your brakes on your car? Are you going to fix your car before it breaks... I better give this a break. ....
Old Jun 20, 2007 | 10:22 PM
vaughn1576's Avatar
vaughn1576
What I think ctwentytwo means to say is that the part of your car you are referring to has the proper spelling of "brake". He also wanted to mention that if you spell it wrong your post will not get the type of attention you are looking for. He probably thinks you should edit your post.
Old Jun 20, 2007 | 10:49 PM
BlackZ05's Avatar
BlackZ05
Whoops thats what i get for just throwing **** up fast
Old Jun 21, 2007 | 12:07 AM
ctwentytwo's Avatar
ctwentytwo
which break light BTW? Kidding... is it the brake light on the dash, or your rear brake lights on the rear bumper?
If it's the one on the dash, you need to check the brake fluid reservoir.
Old Jun 21, 2007 | 08:04 AM
BlackZ05's Avatar
BlackZ05
one on the dash i'll check it.
Old Jun 21, 2007 | 08:23 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
+1 and if so it makes this another thread where someone says "my brake light is on"
Chris
Old Jun 21, 2007 | 10:06 PM
BlackZ05's Avatar
BlackZ05
I'll know tomarrow if it was the brakes setting it off, even though it only happened with I was driving hard.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
