buffing out rubs/scratches?
Old May 7, 2003 | 03:35 PM
indulf's Avatar
indulf
Default buffing out rubs/scratches?
hi all-
hay bail fell off of a truck in front of the wife today on the way home. she ran smack into it and it left some rub marks (not quite scratches) on the front bumper.
any suggestions on how to buff these out? any special compound to use? techniques?
also, the impact seemed to jog one of the marker lights out of place in the bumper. how do i get up under there to rest it into place? it has to go to the dealer next week, should i just let them take care of it?
thanks-
indulf
Old May 7, 2003 | 04:27 PM
Eric1h's Avatar
Eric1h
go to any auto parts store and buy some mequires scratch remover. get a nice soft microfiber towel and follow the directions on the bottle, works great, as for the loose sidemarker if you jack the car up in the front end, remove the underpan, theres like 12-13 little bolts pull the black plastic pan off and check out the marker, most likely it tore the plastic but you can check it out. good luck and have fun
Old May 8, 2003 | 03:19 AM
indulf's Avatar
indulf
thanks, ill go get some on the way home tonight.
as for the marker lights, they aren't completely out of position. i am hoping nothing was torn, but ill see when i get under there.
maybe its a good time to get some led side markers?
thanks-
indulf
Old May 8, 2003 | 11:52 AM
Zulu's Avatar
Zulu
I haven't tried Meguiar's, but i've used Mothers Gold step 2 and it works just fine, even on a scratch that I made worse with rubbing compound. Note: if you are using rubbing, make sure it's fine grade, not the coarse stuff, and then use the scratch remover.
Old May 8, 2003 | 03:22 PM
Eric1h's Avatar
Eric1h
yup, be careful whenever using a rubbing compound, it can wear through a clearcoat pretty quick. From the sounds of it a nice light scratch remover will do the trick
Old May 9, 2003 | 04:01 AM
indulf's Avatar
indulf
im not the biggest meguiar's fan, but scratch-x worked great for me last night. it took all the scuffs out of the bumper and drastically improved the one scuff on the hood. its not big enough for me to worry about now. ill get the body shop to fix it when it goes in next week for the dents in the rear hatch
thanks for the advice all-
indulf
zorrocar1
Cleaning & Detailing
Aug 16, 2004 10:04 AM
jhchan
30
Jun 8, 2004 07:31 AM
zorrocar1
May 1, 2004 12:41 PM
Primaltone
Oct 31, 2003 04:26 PM
vice86
Aug 21, 2003 06:28 AM
