After Tints No More Partial Seal of Window WTf?
Old Jul 25, 2007 | 09:23 AM
A.E.S.S.'s Avatar
A.E.S.S.
Default After Tints No More Partial Seal of Window WTf?
Hey Guys,
I just noticed that our car's window goes down when you open the door ever so slightly & then seals when you close the door for a tight fit. After tints my window doesn't do this anymore! Anyone have any suggestions or ideas as to why this is happening? Has this happened to anybody else? Feedback will is much appreciated.
Old Jul 25, 2007 | 10:52 AM
iseven's Avatar
iseven
after i got my door repainted from an accident, my door window would go up then instead of stoping it would hit the top then go down to half way. i just took it back to the dealer and they fixed it. best bet is just take it to the dealer and let them fix it.
Old Jul 25, 2007 | 11:14 AM
350Z84's Avatar
350Z84
I'm getting a new window and tint done on it this Saturday. I hope this doesn't happen to mine.
iseven, did you have the dealership work on the car from the accident and that is why they fixed it? Or, was the work done at another shop and the dealership went ahead and took care of it?
Old Jul 25, 2007 | 12:12 PM
MustGoFastR's Avatar
MustGoFastR
There is a black pressure switch on the door sill that when released (door opened), the window indexes down, and back up again when the switch is engaged (door closed). Since this action can mess up the bottom edge of a fresh tint job, and for ease of installation of the tint all the way to the botton of the window, your tint shop likely disabled the switches (either by taping them closed or by loosening/removing the screw in the middle of the switch) and forgot to re-enable them when they were finished. Check the switches to see if they're taped down and check to see if the screw in the middle is present, and if it is, that it's tight.
Old Jul 25, 2007 | 01:01 PM
brigz's Avatar
brigz
Like ^^^ said, make sure the screws are still there. My tint man unscrewed them so they wont roll up/down during the curing period.
Old Jul 25, 2007 | 02:46 PM
Get_Zwole's Avatar
Get_Zwole
prob what he ^^6 said i know alta meere in my area does this and they fix it before you leave. prob just forgot.
Old Jul 25, 2007 | 03:32 PM
A.E.S.S.'s Avatar
A.E.S.S.
thanks guys for the feedback. Today when I left work I noticed the passenger-side window works properly & my driver-side window actually does this too but barely! From the inside you can tell because of the sealing sound from the glass to rubber weather stripping. I also noticed that it appears to be slightly un-balanced almost as if it's tight towards the front of the car & just fine towards the rear of the car. Is this bad for the car? The seal that is made at the top is even & unproblematic.
Old Jul 25, 2007 | 03:38 PM
A.E.S.S.'s Avatar
A.E.S.S.
Iseven,
My door also does this, if I lift the lever for automatic closure the window goes all the way up then comes half-way down. Our manuals do state though that this is a safety feature & can be triggered by variations in weather. This also happens to mine but only to my driver side! I wonder why? I wonder if the car could be hotter on the driver side. I think I will check the vent & when I turn the AC on, I will direct it to the window. Maybe this will work!
Old Jul 25, 2007 | 05:31 PM
iseven's Avatar
iseven
Originally Posted by A.E.S.S.
Iseven,
yes it was annoying cause i would have to basicly hold the window up button till it stop at the top. i just took it in and it seem like a minor fix they didnt charge me any.
my door was repainted to match the rest of the car by another shop, but the dealer took care of it anyways.
i am getting tint soon also, hope i will be luckier
Old Jul 25, 2007 | 08:50 PM
A.E.S.S.'s Avatar
A.E.S.S.
Though your tint guy will tell you this, I will remind you not to roll your windows down for a day or two.Then it will be ok. Good luck & hope
your enjoy tint!
Old Aug 2, 2007 | 12:01 AM
350Z84's Avatar
350Z84
Mine is doing this same thing now. I did the window motor reset, and it is better. I can tell the passenger window is not sealing like it previously was, and can't figure out what else could be the problem. I tried the reset thing twice. I now get a whistling noise at high speeds out of that window, and I can tell it is not sitting all the way up when the door is closed like the drivers side is.
Any ideas???
Rev_Night
Nov 7, 2020 06:00 PM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
allmycarsdie
May 13, 2016 04:38 PM
350z82
Oct 1, 2015 06:25 PM
AP350z223
Sep 8, 2015 04:38 PM
