help with spacers...
i cant afford new wheels right now. the wheels i have now are not the right offset for the Z and its buggin me more and more. hopefully instead of bashin me for the chrome wheels...maybe someone can tell me if a set of 25mm spacers would help my problem?
ive searched plenty...just curious about them specifically on the setup i have. thanks
FRONT- 245/35 R19 width:8.5 offset:35
REAR - 275/35 R19 width:9.5 offset:45
bought them here almost a year ago...
http://cgi.ebay.com/ebaymotors/19-Ch...spagenameZWDVW
Ouch, those are extremely tucked. Definitely not sized for a 350z.
If you want them close to flush you'll have to run about a 25mm spacer up front and a 35mm spacer in back, or as close to that as possible...
Originally Posted by AroundMyHorn
man i ordered spacers and the studs were still too small. make sure you get looooong ones.
Originally Posted by taurran
25mm+ spacers should come in the type that include a 2nd set of lugs and stud extensions. Make sure you get them and you won't need to mess with logner studs.
stud extensions huh? damn.....wish i knew that.
Originally Posted by rx7/350z
I have a set of 25mm h&r spacers that bolt on and use their own studs. I think they were called Drm or something. Pm me if your intrested
alfhasg35
Wheels Tires
15
Oct 4, 2011 01:21 PM
