How to remove front reflectors without removing bumper
Old Aug 22, 2007 | 10:14 AM
soshiv's Avatar
soshiv
Default How to remove front reflectors without removing bumper
Is there a trick to removing the front reflectors without removing the bumper, i have heard that people have done it but damn i cannot get a screwdriver to work no matter what length, i have used a stubby one and a longer one with no success... anyone know a secret?
Old Aug 22, 2007 | 10:16 AM
Jay'Z's Avatar
Jay'Z
I have done it with success.. either you can go through the fender well or.. Go underneath the underpanel.. What have you had no success with/??
Old Aug 22, 2007 | 10:23 AM
dkmesa350z's Avatar
dkmesa350z
the windshield fluid makes the passenger one a bit tricky, but it can be done through the underpanel. But just take the bumper off if you are having trouble...it is a synch. Just remove 6 clips up top, 2 bolts where it meets the fenders, and 10-12 bolts on the underpanel. It took me 10 minutes
Old Aug 22, 2007 | 10:25 AM
Jay'Z's Avatar
Jay'Z
I would have to say taking the bumper off is mad easy..
Old Aug 22, 2007 | 10:58 AM
soshiv's Avatar
soshiv
the top screw on the reflector is totally blocked by the washer fluid bottle, cant get a screwdriver even into it, i tried pulling the bumper away a bit but still no success, i guess ill just have to take the bumper off, thanks guys
Old Aug 22, 2007 | 11:00 AM
iStan's Avatar
iStan
ZR
It's possible, but I prefer removing the bumper. Good time to clean out all the sht stuck on your ac condensor.
Old Aug 22, 2007 | 11:10 AM
saberphx's Avatar
saberphx
I did it without removing the bumper, couple of arm scratches later...
Old Sep 8, 2007 | 08:52 AM
97mx5's Avatar
97mx5
It really was not that difficult -- shorty 10mm wrench will access the bolts/nuts for the washer bottle -- slide it out of the way, remove s/m
Old Sep 8, 2007 | 09:00 AM
350Z84's Avatar
350Z84
I did it with the bumper on. I also removed the splash guard and went up from the front. The drivers side I could slide my arm up in there and get to both screws with a screwdriver.
However on th passenger side I used the phillips head part from one of those multi-head screwdrivers, that was only like 1 inch long. I then used a 1/4" ratchet with the correct socket that the multi-head would fit into and was able to unscrew it like that. It was a pain getting the reflector out of there though. I was able to finagle it through to come out the front of the bumper.
Old Sep 8, 2007 | 12:57 PM
md350's Avatar
md350
You don't have to completely remove it. I did one side at a time, removed just as many screws as I needed to pull it back a little bit. I did the actual change from above - much easier.
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
