AC Smell...
Old Oct 8, 2007 | 01:55 PM
behjjeh's Avatar
behjjeh
Vendor - Former Vendor
Default AC Smell...
is there any way to get rid of AC smell????
Old Oct 8, 2007 | 02:41 PM
usmanasif's Avatar
usmanasif
Not really. It is quite normal and from what I know, unavaoidable. Unless yours smells for unusually long after turning off the compressor, i would just roll down the windows
Old Oct 8, 2007 | 02:46 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
The smell comes from mildew/mold that lives in the air ducts .
The only way to get rid of the smell is to completely dry out the mildew, or to kill it.
Try blasting the hottest dry air you can (set to all the way hot with A/C on, fan on maximum) for 10-20 minutes.
The best way to avoid the smell is prevention.
When you are using your A/C, moisture can collect in the ducts. This is how the mildew grows.
Before you shut down your car, turn the A/C off and blast warm air for 30 seconds - 1 minute to dry out the ducts.
There is also a product called Ozium that works pretty well at removing this smell. You have to spray it into the air inlet for the air conditioning, and I'm not sure where that is located.
Old Oct 8, 2007 | 04:14 PM
djnc's Avatar
djnc
nose plugs
Old Oct 8, 2007 | 04:20 PM
slowxturtle's Avatar
slowxturtle
You should be warned that Ozium is known to significantly increase prostate cancer as well as colon cancer.
damonchoy
Aug 5, 2014 01:07 PM
Rocknthehawk
Apr 6, 2010 12:21 PM
shawberger
Jul 7, 2009 04:51 PM
robertsowka
Feb 19, 2008 04:57 PM
Murfdizzle21
Dec 28, 2007 04:44 PM
