Dome lights do not function.
Old Oct 10, 2007 | 07:34 AM
aggie05's Avatar
aggie05
Default Dome lights do not function.
My dome lights quit working , fuse?
Old Oct 11, 2007 | 03:48 AM
Scarab440's Avatar
Scarab440
could be a fuse. When it happened to me it the was the BCM (body control module) getting confused.. I unhooked the batter for a few mins, reconnected and everything is working great a year later.
Old Oct 11, 2007 | 06:02 AM
rxkevin's Avatar
rxkevin
Fuse is near the driver side pedels. It should be named "Interior lights" I believe. But if the dome lights do not work, I believe the cig outlets shouldn't work either. So that could be a quick test for you.
Old Nov 11, 2007 | 03:32 PM
infamous350's Avatar
infamous350
that just happened to me today i ran my sub wires. And my head unit and interior lights werent werking. I replaced the audio fuse under the hood and hte head unit worked again. But the dome lights dont work now. I dont think its a fuse near the clutch. they looked good i didnt pulled them out but i used a flash light and i could see the inside pretty well. I think maybe the bulbs could have blown when the fuse for the audio blew. Anyone evere have there bulbs blow. Or maybe i need to disconnect and reconnect like that guy said
Old Nov 12, 2007 | 07:55 PM
Scarab440's Avatar
Scarab440
try what the guy said... what do you have to loose?
Old Nov 21, 2007 | 02:38 PM
350ZTheStandard's Avatar
350ZTheStandard
Just replace the fuse even it if it doesn't look blown then check to see if they are working, this is very cheap $$$ wise. If not do what the others here have said.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
