Dome lights do not function.
Tried the search key with no results, maybe im just being noob here but i cant get my dome lights to come on. CHecked the fuse in the kick panel and the bulbs seem to be okay.
Any suggestions.
Any suggestions.
i had the same problem, try disconnecting the - terminal on the battery for a few mins, then reconnect. i did this and the dome and mirror lights started working again. There is a TSB from nissan on this, if disconnecting the neg terminal then you would need a new body control module
Hope this helps
Hope this helps
Yup....it was the BCM. I pulled the negative side of the battery, stepped on the brakes to drain any residual charge, reconnected and everything is a OK now. I wish all fixes were this easy. Thanks!
