How do you pop Nissan badges off?
Old Jun 5, 2003 | 05:07 AM
vice86's Avatar
vice86
Default How do you pop Nissan badges off?
I want to get the Z badges but I have no clue how to pop out the Nissan badge in the front or back...I'm afraid I'll ruin the paint or scratch something....any tips?
Old Jun 6, 2003 | 12:37 AM
joust75's Avatar
joust75
They are attached by adhesive. Heat them up with a hairdryer. Then find a secure way to grip them and they will come off easy enuff. I have already killed the 350z lettering this way.
Old Jun 6, 2003 | 04:55 AM
vice86's Avatar
vice86
Thanks for the info!
Old Jun 6, 2003 | 09:49 AM
DJCruzControl's Avatar
DJCruzControl
I typically use a hammer.
Old Jun 6, 2003 | 11:24 PM
AREITU's Avatar
AREITU
Running some floss behind the emblem while applying heat might help it come off faster.
Old Jun 7, 2003 | 12:30 AM
joust75's Avatar
joust75
Good idea. Maybe some 50 lb test fishing line would work too!
Old Jun 7, 2003 | 06:22 AM
FLY BY Z's Avatar
FLY BY Z
Aren't there holes behind the Nissan badges which would indicate more than just glue is holding them on therefore floss and heat won't work?
Old Jun 7, 2003 | 02:48 PM
joust75's Avatar
joust75
No. The holes and posts are there to ensure the badge goes in/ stays in the proper position, not to hold it on. That is the adhesives job.
Old Jun 7, 2003 | 02:57 PM
ztom's Avatar
ztom
Yeah, there are holes, but they are there just so you can line up the emblem (which have posts in the back) correctly.
Tried floss, and after 1/2 hour of tearing up my fingers, used a different method:
After heating with hair dryer (on low, so as not to melt the "Nissan" emblem), I slid a 6" thin plastic ruler under one of the wings. Then with more heat, I used a thin (then thicker) screwdriver (resting on the plastic) to SLOWLY pry the emblem up. Scrapping the old adhesive pad off with my fingernails took some time. Removed the last of the adhesive with "Bug & Tar Remover", which smelled like turpentine (which it probably is).
Old Jun 7, 2003 | 03:43 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I second that emotion!
I used a thin putty knife padded with soft athletic tape and pried (after heating) inside the Nissan emblem as opposed to on the periphery. I figured if I scratched anything there, the new Z emblem would cover it.
I tried the fishing line and almost cut my fingers off with no luck.
The grayish adhesive left behind came off really easily after I heated it up as well. It then sort of rolled off with simple finger pressure. I then wiped with a cloth and popped in the new emblem:
Attached Thumbnails How do you pop Nissan badges off?-front-z-emblem-001.jpg
Old Jun 7, 2003 | 03:44 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Close up:
Attached Thumbnails How do you pop Nissan badges off?-front-z-emblem-007.jpg
Old Jun 8, 2003 | 04:04 PM
brakedustZ's Avatar
brakedustZ
Default mmm, sexxy
That is one of the sexxiest things i think ive seen
where did you find them? Ebay?
Old Jun 8, 2003 | 05:11 PM
vice86's Avatar
vice86
www.courtesynissan.com brakedust
Old Jun 8, 2003 | 06:08 PM
tsixr's Avatar
tsixr
Does anyone have any pictures of the Z emblem on the back of the car?
Old Jun 8, 2003 | 07:55 PM
alex30327's Avatar
alex30327
Originally posted by Dr Bonz
Close up:
Bonz,
What kind of front grill do you have on your car, and where did you get it?
Old Jun 8, 2003 | 08:34 PM
joust75's Avatar
joust75
Originally posted by alex30327
Bonz,
Ha! It looks pretty good dont it Al boy? It is a $12 mod. It is chrome door guard trim, that crafty owners have put on their grill! Many have done it! Do a search and you can find loads of pictures and advice for install!
Old Jun 9, 2003 | 02:57 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Actually mine was about 8 bucks. You buy that flexible "chrome" door edge guard at Auto Zone and peel off the adhesive backing and stick it on after you cut it to length.
Old Jun 9, 2003 | 03:39 AM
apsilon's Avatar
apsilon
Anyone know if the rear emblem has posts? I'm thinking about removing all of the badges from my Z but ATM can't be bothered filling and painting.
Old Jun 9, 2003 | 08:47 AM
joust75's Avatar
joust75
Yes It does.
There is a picture of what it looks like floating around somewhere. there are 2 one larger than the other in a horizontal line from eachother.
I feel the same way. i dont really want to pay to have it filled.
i am either gonna find some little rectangular badge related to zness in some way, or I will buy a small circular Z logo to cover it up.
Old Jun 9, 2003 | 12:58 PM
alex30327's Avatar
alex30327
I used a heat gun that I got at Home Depot for $24. I had no problem getting my old badges off, but destroyed them in the process. I put damp towels around the parts of the car I did not want to heat up, and used a pair of pliers to tear the old badge off once the old badge was pretty much melting. Installation was easy except for in the rear. I accidently put the new badge on the back offcenter. I had to tear it off and reposition it to get it perfectly center.
07ZEKE
Aug 23, 2021 09:15 PM
sales@czp
Sep 23, 2019 03:30 PM
kyin
Oct 15, 2015 05:54 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
