Led lighting problem.
Old Jan 31, 2008 | 04:01 PM
blazed54's Avatar
blazed54
Default Led lighting problem.
Hey, I just finished installing a led strips in the footwell of the driver and passenger side. Following the instructions found in the diy, I found the right wires in the A pillar and tested everything to make sure it works.
It was working fine as i hooked up the first led under the drivers side (light came on perfectly). But after i extended the power from the drivers side to the passenger side and hooked the second one up, nothing works anymore!!!
None of the led's turn on, the dome light doesn't turn on, even the push in lights next to the dome don't come on. Everything else with the car works so I have to assume that i blew a fuse somewhere....I don't know how since the wires coming from the led lights themselves are like 24 guage, which i assume means it drains very little power.
If anyone could help me I'd appreciate it thanks.
Old Jan 31, 2008 | 05:36 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Did you disconnect the battery while you were installing? If you didn't, it's quite probable that you popped the fuse. Replace it and see what happens.
Old Jan 31, 2008 | 05:38 PM
sintaxeror's Avatar
sintaxeror
sounds like you blew a fused.. the gauge of wire you were working with is plenty big enough to blow a fuse.
Old Jan 31, 2008 | 10:34 PM
blazed54's Avatar
blazed54
ya i didn't disconnect the battery. anyone know where the fuse is located or if i can buy it at my local autozone? or do i need to get it replaced at the dealership?
Old Feb 1, 2008 | 12:43 PM
Daytona350Texas's Avatar
Daytona350Texas
You're fuse box is located next to the clutch on the left side against the inside footwell wall. It has a fuse puller inside it, just read the inside of the panel and it tells you which fuses are to what. And I believe its a 15, you can buy it at any auto store
Old Feb 2, 2008 | 03:39 PM
blazed54's Avatar
blazed54
thx found the blown fuse and changed it out with the spare. everything works fine now
loudtoyz
Apr 6, 2023 04:52 AM
liqalu04
Jan 2, 2022 12:58 PM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
