Paddle Shifter OEM wheel
Old Feb 4, 2008 | 01:28 PM
Oleg's Avatar
Oleg
[QUOTE=z-u-later]me too...
1. AlvinHuyN
2. z-u-later
3. Oleg
Old Feb 4, 2008 | 05:31 PM
MaRbLe's Avatar
MaRbLe
Originally Posted by james840a
The one im working on, shouldnt have anymore of a delay then the oem. But i havent wired it yet, so im not 100% im just going on the fact im using the same switches as the oem shifter is.
My proto-type is going to be hard wired. But IF i do production it will be a bolt on and plugged in harness/adaptor.
Im, definatly interested how this turns out. Delay was my biggest issue with getting the paddles...
Old Feb 4, 2008 | 05:36 PM
Ghost 350z's Avatar
Ghost 350z
1. AlvinHuyN
2. z-u-later
3. Oleg
4. Ghost 350z
As long as its fairly priced, im in Id love to have paddles and keep my airbag
Old Feb 4, 2008 | 05:38 PM
Ghost 350z's Avatar
Ghost 350z
Manual Mode is electronic already. There should be no more delay than there already is
Old Feb 5, 2008 | 04:26 AM
chsia's Avatar
chsia
Default I want one
1. AlvinHuyN
2. z-u-later
3. Oleg
4. Ghost 350z
5. chsia
Old Feb 5, 2008 | 04:43 AM
Greedy4nismo's Avatar
Greedy4nismo
Originally Posted by widebody350
This can be used with a 6MT?
...no, this relies on an automatic transmission and clutch control, as with all other sequential paddle shifting. This one doesn't really do anything different than using the manual mode of the automatic shifter, which means it won't be any harder on the transmission and engine than if you simply used the automatic shifter to change gears like AT owners can do already.
I own a 6MT, and don't know that i'd ever go to an AT, but this looks very polished and refined. I'd say that if you do go to production, make the paddles the same color as the steering wheel inserts and you'll have alot more people buying it.
Old Feb 5, 2008 | 06:25 AM
badkarma85's Avatar
badkarma85
What is the ball-park figure of this if it goes into production?
Old Feb 5, 2008 | 09:13 AM
MaRbLe's Avatar
MaRbLe
People have posted there being more of a delay with the paddles added...
Old Feb 5, 2008 | 02:35 PM
aloh's Avatar
aloh
1. AlvinHuyN
2. z-u-later
3. Oleg
4. Ghost 350z
5. chsia
6. aloh
I dont see why there would be an added delay as some people have said. It doenst make sense to me. Its still sending the same electrical signal for an upshift or downshift...so how can relocating the switches affect it? I just dont get it. If its going slower, then somebody did something wrong when designing/building it. I'd just like to know what could cause a delay.
James, when you get it working, give us some feedback about the response time.
Also, just my own suggestion, if you could use paddles that are simliar to the ones on G35's then it'll look pretty OEM.
Old Feb 5, 2008 | 02:39 PM
Ghost 350z's Avatar
Ghost 350z
Im sure they did post it, I just do not see how it is possible.
Old Feb 5, 2008 | 03:37 PM
WTX350Z's Avatar
WTX350Z
I'm interested...assuming price is reasonable I'm in.
Old Feb 6, 2008 | 07:02 PM
james840a's Avatar
james840a
Originally Posted by Lawy'dU
zack's kit for the 03-06 g35 should work for the Z. He's pretty much done with the kit as well.
Are you talking about this kit?
If so, i dont think it will work for the 350z because the paddle shifter switch on the right side is to deep and would hit the key switch on the column. Youd have to mount the unit lower and i think that would not be comfertable. But i might stop by and talk to Jason at Riverside Infinity and check them out since i drive by everyday on the 91
Old Feb 7, 2008 | 05:30 AM
daverx7's Avatar
daverx7
...Subscribing...
Interested to see price range.
-Dave
Old Feb 7, 2008 | 06:04 AM
nothix's Avatar
nothix
subscribing too ^_^
Old Feb 7, 2008 | 08:35 AM
cheshirecat79's Avatar
cheshirecat79
There's a couple of videos floating around showing the "other" paddle kit in action. There's definitely a delay when using the paddles. If this kit can get rid of that delay then you'll have yourself a winner.
Old Feb 7, 2008 | 08:37 AM
italmark82's Avatar
italmark82
looks like you only have 1 pedal, no braking necessary?
Old Feb 7, 2008 | 08:54 AM
james840a's Avatar
james840a
You mean the this one?
Old Feb 7, 2008 | 08:59 AM
  #38
k6750gsxr's Avatar
k6750gsxr
that is one ugly beach....
Old Feb 7, 2008 | 01:07 PM
  #39
Oleg's Avatar
Oleg
I'd still hit it...
Old Feb 7, 2008 | 02:31 PM
  #40
MaRbLe's Avatar
MaRbLe
Thats the one I saw, then a post or 2 about it on here or on 350zmotoring.
