03 lights in 06+headlight housing
Old Feb 4, 2008 | 10:04 PM
litlechina's Avatar
litlechina
Default 03 lights in 06+headlight housing
will the 03-04 HID igniter/bulbs etc work with the 06+ headlight housing?
Old Feb 5, 2008 | 12:23 PM
Mr Zipps's Avatar
Mr Zipps
03-05 HIDs are D2R and 06-08 HIDs are D2S. They are the same bulbs with different notches at the base. You can use a D2R bulb in a D2S socket by dremeling an extra notch into the D2R base. Let me get a picture of both bulbs and I will show you.
I'm not sure about the ballast. I know they are very similar and look about the same size. The only thing I would be worried about is mounting it. Not sure if the holes line up.
Old Feb 5, 2008 | 01:24 PM
redlude97's Avatar
redlude97
They are not the same. D2r bulbs have a ceramic shielding painted on the glass to limit glare in reflector housings. When used in projector d2s housing, they will have less output than a d2s bulb. You can scrape the ceramic shielding off, but it will still never be the same as a d2s bulb
Old Feb 5, 2008 | 09:10 PM
litlechina's Avatar
litlechina
thanks guys..
Old Feb 13, 2008 | 03:02 PM
WhiteOnWhite350z's Avatar
WhiteOnWhite350z
can the 03 ballasts be used on 06's?
Old Feb 14, 2008 | 07:07 AM
buffmanjeff's Avatar
buffmanjeff
Yes, I swapped my 03 lights with a guy that had an 06. Plug and play for both of us.
Old Feb 14, 2008 | 07:31 AM
lowrider's Avatar
lowrider
+1. Plus, the scraping is a lot of work for what? And, remember you can't get any body oils on the glass or they will prematurely fail. Buy the correct bulb.
Lou
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
